Airbus organise le 15 et 16 octobre une conference le 15 et 16 octobre à Toulouse sur les LENR:
http://www.e-catworld.com/2015/07/01/ai ... n-october/
E-cat d'Andrea Rossi: le retour !
moinsdewatt
- x 553
détails :
Goals and Format
Hydrogen gas loading is a promising technology to reliably create thermal and nuclear anomalies. The purpose of the workshop is to bring together an international group of experts to present their results and encourage discussion. The emphasis is on theory, models, explanations, but novel experimental results will also be accepted. In addition there will be discussion on sujets of interest.
The working language of the workshop is English.
Papers
The program will consist of both invited and contributed talks. Oral papers are invited and will be reviewed by the Committee. It is essential that all presenters submit a 1 page Abstract in MS Word format (A4 paper size) (see Important Dates below). You are encouraged to support your presentation with a poster paper. A bronze medal will be awarded for the best poster paper. Authors should estimate 30 minutes for each presentation but variations on this time (e.g. 1 hour) can be made by arrangement. Power Point presentations are preferred. (Bring a USB memory key or CD-ROM or DVD-R.).
All presentations and papers should have numbered pages and the filename should start with the presenter's surname (Further instructions will follow). The organization will compress your submission into portable document format (.pdf) for publication on the ISCMNS web-site and DVD-R and will be freely available for download. Presentations will not be published on-line until 15 October and may be modified or withdrawn by the authors at any time. A book of the proceedings will be printed.
- elephant
- x 7
Espérons que ça va encourager les labos industriels et académiques à se bouger un peu: si déjà quelques travaux " sortaient des courbes " sur le hot cat ( p. ex. des rapports rendement/proportions, températures de démarrage, température d'extinction, durée de la réaction, etc....),on avancerait considérablement dans la compréhension du phénomène.
- elephant
- x 7
Une réplication réussie du hot-cat à l'université de Moscou.
Pendant 1 h, 2100 watts pour 850 consommé, après 3 essais " ratés" ( par destruction du dispositif )
http://www.lenr-forum.com/forum/index.p ... t-of-Mosc/
- antoinet111
- Grand Econologue
- x 1
- elephant
- x 7
Pour cet essai là, oui.
Mais il est trop tôt pour en tirer des chiffres opérationnels. Entre le truc " prêt à sauter " et une recette bien précise avec des courbes de rendement, il y a encore du pain sur la planche...
Espérons que toutes ces réplications finiront par convaincre un ou deux profs d'univ de laisser un doctorant s'intéresser de près à la réaction et de tirer des courbes:
proportion des réactifs / rendement
quantité des réactifs / puissance.
J'ai l'intuition ( rien de plus ) qu'on est encore loin du rendement optimal. Actuellement, on travaille avec de petites quantités de réactifs ( sinon le réacteur s'emballe ). Quand on en saura plus on pourra dessiner un autre type de réacteur, bardé de capteurs, modulable à volonté et obtenir de meilleurs rendements.
- antoinet111
- Grand Econologue
- x 1
moinsdewatt
- x 553
Merci Moinsdewatt.
- 23 Réponses
- 19496 Vues
29/08/12, 19:50Un sujet posté dans le forum : Innovations, inventions, brevets et idées pour le développement durable
