je vois pas mal de pubs faisant éloge de produit quasi-miraculeux les panneaux solaire à "tubes sous vide" !
Certains de vous auraient-ils des infos et/ou expérience sur cette techno. ??
Merci d'avance
Chris.
chris34 a écrit :bonjour à tous !
Merci d'avance![]()
Chris.
In the field trial, there was little difference between the
total solar energy yield of those installations that used
flat-plate solar collectors and those that used
evacuated-tube solar collectors
The trial found that the way householders use their solar
water heating system is critical in achieving the best
results from solar water heating systems. Better advice
to users on how to control their solar water heating
systems (in terms of volume of hot water use, timing of
back-up heating and hot water use, and temperatures
required) is essential
A well-installed and properly used solar water heating
system is likely to provide carbon savings. The typical
savings are 230kg/year when replacing gas and 510kg/year
when replacing electric immersion heating.
