Andrew
New 4 stroke engine (en anglais)
- inventor
- J'ai posté 500 messages!
- x 82
Re: New 4 stroke engine (en anglais)
In this film, you can imagine that on the other side of the valves there is the same disc as at the top and of course the wedges when it is to be closed, does the same at the bottom as this disc at the top of the springs
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Well, here in the film you can see that the valves are almost not open at higher revolutions .. The same is seen this opening, the air that is to enter the cylinder ..
And the sound that this mechanism produces is huge .. You can take my word for it that the whole sound (95%) of the four-stroke engine comes from the timing mechanism ...
My engine has only 5% of this mechanical sound,
But on the exhale ... world record ...evil
http://new4stroke.com/zawory%20napedzane.mp4
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Did you like my balloons? It is a buoyancy engine .. There are already such, but operate under water .. are exceptionally fuel efficient vehicles, which you once, then 3 seconds using energy and emerges again up .. Of course the circulation of Carnot have nothing to do, although in the level covers considerable distances but the faithful his followers will try to convince us that they have ... But they do not have an orthodoxy should not be ... despite teach this way at universities ...
First about the underwater glider, of course in English .. https://en.wikipedia.org/wiki/Underwater_glider
If someone needs it, you can already buy it ... maybe even a sailboat would be towed
http://www.teledynemarine.com/slocum-glider?ProductLineID=14
Technical parameters .. http://www.teledynemarine.com/Lists/Downloads/Teledyne%20Webb%20Research%20Brochure%20G3%202017_pages.pdf?fbclid=IwAR0zJtGVQOUE-SQK2lHRCcgVxlShvK7Xb7KtUgeiE4YnuVXQ4yHh0ayJsSM
We develop thinking further, not burdened by this Carnot ..
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
There was once a discussion on this subject .. I used to think so until 1980 ... But later I looked at it differently and I know, as a result of years of reflection and experience, that all this is sucked from the finger, these heat and mechanical losses, unfortunately .. Here is an evident example showing that the resistance to movement of the crankshaft and the camshaft is several times larger, so these charts are a complete fairy tale ..
And that's why they are not building new efficient engines ... previous engineers. and until they revise their views, they will not build a better engine .. Here you stubbornly do not see that my engine with the same capacity, the main piston sucks 3 TIMES more air into the cylinder, and you try to compare it to a traditional engine that sucks 3 times less ,, And you say that the losses on my pistons according to these graphs are much larger .. Yes, maybe (but I'm not sure) but they suck these 3 times more charge into the cylinder and This is an undeniable physical basis, but my engine must be more efficient , no matter whether you acknowledge or not...
you can see that the shaft itself is very light, you can turn the hand, it is very difficult to mount the camshafts, even using a long arm wrench .. I think that even 5 times more force is needed for this .. I used to rotate several engines that I modernized and I repaired and I know that this is a big difference in this strength .. And this will also be confirmed by every efficient engine mechanic...
And that's why modern engineers, unfortunately, put them down and are unable to make a working engine from 23 HP to 250 HP ... and until they start to find out, however, it is, they will not do it ... And I do a lot so that they deign find out ... until health allows
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Here, such false graphs are:
https://x-engineer.org/automotive-engin ... Mba2uTqzBg
You can see that the shaft itself is very light, you can turn the hand, it is very difficult to mount the camshafts, even using a long arm wrench .. I think that even 5 times more force is needed for this .. I used to rotate several engines that I modernized and I repaired and I know that this is a big difference in this strength .. And this will also be confirmed by every efficient engine mechanic...
And that's why modern engineers, unfortunately, put them down and are unable to make a working engine from 23 HP to 250 HP ... and until they start to find out, however, it is, they will not do it ... And I do a lot so that they deign find out ... until health allows.
These and this graph shows that the valve train movement resistance, despite increasing the turnover by 6 times, does not consume more energy .. It's some wonders, because they also have their inertia, and bearing resistance also increases, similarly to the resistance in shaft bearings crankshaft ... and as a result of increasing turnover from 1000 to 6000, this green space should be much wider ... .. and this indicates a very unreliable development of this chart. Because the valves also have their inertia, which increases with the square of revolutions, and thus the friction in the drive system of these valves also ...
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
And here, as if someone wants to calculate the displacement of a new engine ... and thus everything you need then, is different from the current engine ..
and the first weld, which you will not see on the animation ... that the minimum volume of the combustion chamber is 370 degrees of rotation of the main crankshaft ..
http://new4stroke.com/volume/volume.htm
http://new4stroke.com/volume/volume.xls
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Here, the only fairly professional book about the efficiency of the current engine .. In Figure 6.9, it is clearly seen that the valve train drive at speeds of the order of 2000 - 3000 rpm is about half of the total power received from the engine, at its partial load .. Thank you Wiley.
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
inventor a écrit :Unfortunately, the Carnot engine is only a fragment of the reality surrounding us related to heat engines .. But most try to explain it as a generally applicable law. In the meantime, for example, you can do a simple experiment at home with a "cold engine". Just pour cold water into the sink and put a screwed plastic drink bottle into it. We will see how it will change its shape due to the cooling of the air inside by cold water. Based on the change in its appearance, we see that also the engine would be possible on this principle. Everything is relative in physics .. But learning about heat omits many important physical quantities such as evaporation, freezing and most important - time. And theoreticians come to the conclusion that entropy is steadily increasing, but what about the scientific approach cannot be reconciled too much, because what will happen if this entropy is ever going to run out ? ;)
I present here, probably the largest heat engine that a man can build (It is suitable for the Guinness book of records ;) ) And theoretically, the pressure does not play any role in it, because the balloon from below is open .. the air heats up and the balloon can rise even at 5000 meters (record is 20,000 m), then the first balloon empties from warm air and fills the second, which thanks to the scrolling line to their tether will do electricity in the generator. Then the cycle repeats, from what we release at the top warm air and the bottom one, we fill it ... The old good principle and pressure does not play any role .. It's just a curiosity that not everything with heat is a Carnot engine ..
By the way, a hot air balloon is the longest-lasting machine in the air so far - the record is over 10 days ...
This shows because maybe there are other heat engines with higher efficiency than currently known .. Anyway. there is already a contribution to new thinking ...
Andrew
Well, here such a movie, if it could work such a balloon power plant .. ;)
Well, for example on a ship, if the exhaust gases from the engine were used, half in the fields with air, so that they were not too hot, then such a balloon with a capacity of 500 KG could be filled in 1 minute, if the ship's engine operated at full power. At one turn gives 20 m ^ 3 a salon with a high temperature .. multiply it by 100 revolutions per minute gives 2000 m ^ 3 .. Probably a few balloons would be needed .. But also such a diesel power plant on the mainland can be improved a little in this way .. to no heat was wasted ...
https://www.new4stroke.com/balons.mp4
of course with any other heat source of 80 degrees Celsius it is also possible ..
Andrew
Andrew Feliks
- inventor
- x 82
That's right, but you can always buy a German product at home, which is the 3rd type of energy on Earth .. And the one who set the law is Lord Kelwin, who thought that birds fly because it is a divine matter ... But that's nobody this sharp view of reality bothers and many repeat it ...
But here is this German idea ...
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
This German idea works or doesn't work, but certainly when applied to my balloons it shows the way to go .. My balloons are not perpetuam motion, just a giant heat engine for low temperature, which has already been proven to work because the balloon is rising due to this relatively low temperature inside.
And this German way how to properly enlarge it, it will work, enabling the previously wasted energy released into the air to use, and it can be energy released into the air from a coal-fired power plant, gas-fired power plant, or four-stroke energy engine (atomic power plants also), which only have no more than 50% efficiency, and the rest they release into the atmosphere And now maybe even with 40% of this energy can be used for electricity production, which can even give 90% of the total efficiency to give us such a new power plant ...
Well, such "balloons" would have to have dimensions of 10 x 20 x 10 meters, and they could be built like scenes at outdoor concerts .. but the skin weight would be balanced, as well as thermal illumination in the form of foam polystyrene lining could be done .. No only the height of the tower is a problem .. Al I think that the height of 200 meters is quite real, that is, say, these 6 pieces of such "balloons" on this tower could work on one side, which would give a pull of up to 3000 KG ..
Well, for example, exhaust fumes from a diesel power plant could be introduced there, and with cooling hot water too .. So theoretically 50% of this heat energy lost in such a power plant could be forced to work ...
Even water vapor could also be used to fill a "balloon" .. its weight is only about 0.5 KG at a temperature of 80 degrees Celsius ..
hot air pump, e.g. power plant chimney ...
and works 24 hours a day regardless of the weather ..
Andrew
Andrew
Andrew Feliks
Revenir vers « Econology forum in english »
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 51 invités
