F*ck you Earth! Ouragans 2017 Harvey, Irma, Jose, Katia...Payback time is coming!
x 12723
Re: Fuck you Earth! Ouragans 2017 Harvey, Irma, Jose, Katia...Payback time is coming!
Message non lupar Christophe » 05/03/18, 17:16
Finalement 2017 n'était pas la pire saison au niveau de l'intensité des ouragans depuis qu'on les mesure (du moins dans l'Atlantique Nord), mais la tendance est franchement haussière: changement-climatique-co2/quelles-sont-la-puissance-et-l-energie-d-un-ouragan-t15359-10.html#p335739
Indice L’énergie cumulative des cyclones tropicaux (en anglais Accumulated cyclone energy ou ACE) : https://fr.wikipedia.org/wiki/%C3%89ner ... _tropicaux
x 12723
Message non lupar Christophe » 29/05/18, 01:46
Une étude du début du mois...émet l'hypothèse d'un rayonnement gamma et positrons dans l'ouragan Patricia de 2015: https://agupubs.onlinelibrary.wiley.com ... 17JD027771
On 23 October 2015 at ~1732 UTC, the Airborne Detector for Energetic Lightning Emissions (ADELE) flew through the eyewall of Hurricane Patricia aboard National Oceanic and Atmospheric Administration's Hurricane Hunter WP‐3D Orion, observing the first terrestrial gamma‐ray flash (TGF) ever seen in that context, and the first ever viewed from behind the forward direction of the main TGF gamma‐ray burst. ADELE measured 184 counts of ionizing radiation within 150 μs, coincident with the detection of a nearby lightning flash. Lightning characteristics inferred from the associated radio signal and comparison of the gamma‐ray energy spectrum to simulations suggests that this is the first observation of a reverse beam of positrons predicted by the leading TGF production model, relativistic runaway electron avalanches. This paper presents the first experimental evidence of a previously predicted second component of gamma‐ray emission from TGFs. The brightest emission, commonly observed from orbit, is from the relativistic runaway electron avalanche bremsstrahlung; the second, fainter component reported here is from the bremsstrahlung of positrons propagating in the reverse direction. This reverse gamma‐ray beam penetrates to low enough altitudes to allow ground‐based detection of typical upward TGFs from mountain observatories.
Un positron est une particule...d'anti matière...
Finalement la nature exterminera peut être l"homme...avant que l'homme ne le fasse... :mrgreen:
x 12723
Message non lupar Christophe » 16/09/18, 16:06
Cela ne se calme pas, je vous présente Mangkhut, super Thyphon de catégorie "6/5" !
x 12723
Message non lupar Christophe » 13/10/18, 23:42
Ils arrivent en Europe...
L'ouragan Leslie s'avance vers le Portugal : il pourrait être le plus puissant depuis plus de 170 ans.
http://www.lalibre.be/actu/internationa ... 805c2f6db7
x 12723
Message non lupar Christophe » 13/10/18, 23:47
enerc
x 255
Message non lupar enerc » 02/09/19, 19:31
Et en 2019 Dorian.
350 km/h de vent en rafales
A mi-parcours sur les Bahamas:
Ca va être chaud au US
x 12723
Message non lupar Christophe » 03/09/19, 11:40
Oui la valeur de 350 km/h m'a intrigué aussi...dans le sens ou je ne pense pas avoir jamais entendu une si forte valeur (280 km/h de mémoire?)...
La puissance éolienne variant suivant le cube de la vitesse entre un "petit" ouragan de cat 5 à 260 km/h et Dorian à 350 km/h il y a une différence de puissance de destruction de (350/260)^3 = 2,4 fois!
Autrement dit une augmentation de 34% (= 350/260) de la vitesse du vent donne 240% de puissance en plus...à contrer, dissiper, lutter contre...
Alors comme suggéré plus haut: il serait peut être temps de faire une catégorie 6 sur l'échelle Safir-Simpson!
x 12723
Re: F*ck you Earth! Ouragans 2017 Harvey, Irma, Jose, Katia...Payback time is coming!
Message non lupar Christophe » 03/09/19, 12:50
Si ils continuent à grossir comme cela, dans 20 ans ils recouvriront quasi tout l'atlantique Nord!
wirbelwind262
x 29
Message non lupar wirbelwind262 » 03/09/19, 17:28
Dans 20 ans, les côtes seront inhabitables, et tu peut pas contrer une quantité d'énergie pareille ....
GuyGadebois
x 978
Message non lupar GuyGadebois » 03/09/19, 21:14
Ah, si on pouvait utiliser cette énergie à notre profit...
