Niveau à laser: How to leveling w/crossed line laser level?
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
x 7972
Message non lupar Obamot » 16/04/12, 16:28
Equipement required:
– a laser bubble-level.
– a reference metallic bubble-level (or precision one).
– a stable photographic tripod in alluminium if possible.
– a plumb-bob.
– a 3M masking tape, for fix the temporary measures on a wall or others targets.
– some permanent pen, to marking and dating the final measured level (when leveling and writing directly on the wall).
(And of course, it's easier with an assistant and binoculars can help too).
x 7972
Message non lupar Obamot » 16/04/12, 16:58
How to adjust your "laser bubble-level", step by step
1) If you dont have one, borrow few minute a "reference bubble level" (also known as a "spirit level"). With a precision of 0.5 mm/m (such as the "laser bubble-level") or better – 0.2 mm/m if possible – because the "reference" must be a tad better than what you would like to adjust:
2) As above: choose a floor that is absolutely flat and leveled properly, like a marble floor or something (such as in the departement stores, for example...).
3) You can check if it's really flat, by doing the first measure with your "reference bubble-level", to obtain that the bubble stick exactly in the middle between the two benchmarks. For examples:
— then turn your "reference bubble level" by 180°... exactly in the SAME location:
— if the bubble continue to stay in the middle, such as here:
... you can be sure, that the floor is flat.
If not, you must change the place until you find a new place that provide same measure (bubble in the center) exactly in the SAME location: again try it, up side down by 90°, 180° (or whatever... everything you can try...).
(Caution: keep in mind that a "reference bubble-level" can be wrong also! Because of a temperature differences or something... Reason why it's necessary to check it also!)
So be carefull, and if you think something go wrong, don't hesitate to change it, for take a try with another one).
4) When you already find the right place that show the bubble in the middle (two times) with your "reference bubble level", you are ready to check your "laser bubble-level". You can just put it on the floor (don't use a tripod to adjust) closer to your "reference bubble-level" (exactly in the same place):
... so, you are ready to check the "laser bubble-level" (by the same way) by comparing with your "reference bubble-level":
5) Then turn your "laser bubble-level" by 180° (but not the "reference bubble-level"):
6) If the bubble stay AGAIN, exactly in the middle you win ! Your level is leveling: well done!
7) If not like here (and before turning by 180° again):
... you must adjust your "laser bubble-level":
... by using one of theses small screws:
8} To adjust, you must doing that on the floor, in the same place of your "reference bubble-level": to compare of course...:
9) Turning the screw a tad (one of them) until the bubble stay exactly in the middle, like here:
... Then, you must turn again by 180° also, to check it again TWO TIMES. Until you are 100% sure about of your laser equipement. But it's easy, because it have two bubble units, and both must be in the middle when checking.
It's possible that you notice a short difference immediately from the step #4 (above) then you need to adjust the level a tad from the first try. This is sometimes because the temperature difference etc... For this reason, you must check your laser bubble-level every times before using it. And sometimes it dosen't match from the first. But sometimes yes: this is normal for a picky equipment!
For training: Here a video:
http://www.youtube.com/watch?v=JDrZLEyGFL8
... that suggest another similar way to do. But unfortunately, by this method you CAN NOT turn all to 180°... So I prefeer the method above to be sure. But that can give you some idea about this.
But as reported by this film, aligning the laser to the opposite, with a second bubble-level (in the field) it's a very good idea...
So go onsite, in the field for leveling your house!
10) Try to find a tripod for photography. Your "laser bubble-level" is adapted to be screwed on it (same standard diameter of the screw).
11) Then you must use the "bubble level" for targeting your house, but first of all:
— you need to adjust the horizontal "laser bubble-level", by using the horizontal bubble (as reported on the video above).
— then you must "plumb" by the same way, but using the vertical bubble:
Take a look to this video, to know how to "plumb", by another explanation:
http://www.youtube.com/watch?v=s1uG9Ds18tQ
So, you can use the vertical bubble AND/OR a vertical reference line that can help, for example: targeting some antenna behind your house or better: use a plumb-bob:
... and compare the vertical laser line with the string attached to the plumb (but you must be sure that your reference line is not biased, of course).
Then, after that, you can turn step by step until 360°, and it must be show the same level and perfect allignment with the vertical line (and the horizontal bubble, must be centred all the time, of course).
Now it's ready to leveling the house!
In the case of this thread, I recommand also, that the owners of the house leveling from inside, using the promenade that turn around the house.
x 7972
Message non lupar Obamot » 17/04/12, 00:51
Here a last video of a"laser bubble-level" very interesting, because it is pretty similar of the PowerFix, and show many applications for to use it, and how you can use (but the Powerfix is easier to use, because of his two laser LEDs that provide crossed lines)
http://www.youtube.com/watch?v=wTFTBeUo ... el&list=UL
What is also interesting with a "laser bubble-level", when using in the night or by sunset, it can extend the range of usable distance.
Capt_Maloche
x 42
Message non lupar Capt_Maloche » 17/04/12, 21:24
Sympa ton sujet
et il a l'air pas mal ce niveau niveau en effet
On le trouve sur le net?
OUCH, OUILLE, AÏE, AAHH! ^_^
x 7972
Message non lupar Obamot » 17/04/12, 22:14
Oui mais envoi seulement en Allemagne. Autrement ils en mettent en vente régulièrement, mais faut attendre! Comme d'habitude dans ce genre de magasins.
x 7972
Message non lupar Obamot » 02/05/12, 01:54
Il y en a peut-être encore. Je saurai ça demain.
antoinet111
Message non lupar antoinet111 » 02/05/12, 14:08
j'ai un niveau laser en croix à balancier, je trouve ça top, pas de réglage, pas de niveau à bulle. juste à la poser et roule.
full automatique
ça sans les niveaux bulles qui ne servent à rien.
http://www.comptoirduweb.fr/F_frame.htm ... t_222.html
Je vote pour l'écriture de post concret et de sens pratique.
A bas les beaux parleurs et les brasseurs d'air !
dedeleco
x 11
Message non lupar dedeleco » 02/05/12, 14:19
Et en plus à 30€ !!
Remarquable !!
précision ?????
peut être trop imprécis ce qui expliquerait le coup de balai !!!
sinon une belle collection de lasers bien plus chers 50 fois :
http://www.debonix.fr/mesures-controles ... ntier.html
avec la précision indiquée 116€ :
http://www.bricoman.fr/m019/niveau-lase ... table.html
x 7972
Message non lupar Obamot » 02/05/12, 14:43
Avec 30€ ? t'en a 3...
10€ chez Lidl. Précision: 0.5mm par m... What else? Attention, ça ne remplace pas un niveau de référence comme celui sur les photos plus haut. Ils en ont régulièrement, mais faut un peu de patience...
AntoineT... un auto-ajustable teuh! J'en voudrais pas même si tu me l'offrais, je préfère le régler moi-même à l'ancienne... Si, si, les bulles servent à quelque chose: le contrôle visuel, là au moins c'est toi contrôle la situation! D'ailleurs le niveau de ton lien en a quatre, regardes bien! Il est indiqué qu'il a une «précision redoutable», bein on aurais quand même bien aimé des chiffres! :mrgreen:
C'est justement parce qu'il n'est pas auto-ajustable que je le trouve bien. Parce que cette référence-là, elle ne change jamais :lol: :
Il vaut les meilleurs professionnels amah (puisqu'en général ils ont des tas de gadgets en plus mais pas autant de facilités évidentes, réunies dans un seul et même appareil). Honnêtement, j'en connais aucun qui a tout ça, et à n'importe quel prix...:
— présentation robuste en aluminium (comme «les grands»...);
— facile à transporter (pas comme certains «grands»!);
— design d'un niveau à bulle traditionnel (qui permet donc de faire des visées efficaces, et pas ces merdouilles de laser tout-en-plastoc, sans recul et sans repères sur le corps de l'appareil – comme certains «grands»...);
— cote de l'axe du laser tracée sur l'appareil (+ échelle centimétrique sur un côté comme certains «grands»...);
— double laser LED en croix! (Comme certains «grands»...);
— embase magnétique très pratique selon les travaux (comme certains «grands»...);
— tige filetée pour le placer sur un trépied photo (donc pas de problème en 360° comme «les grands»...);
— précision de 0,5 mm/m! (Comme «les grands»...);
— et bien sûr, double niveau à bulle (horizontal / vertical) avec rétroéclairage! (Comme certains «grands»...);
— et l'avantage d'avoir une double ligne croisée perpendiculairement, c'est que l'on peut s'aider d'un fil à plomb pour le régler verticalement, pour un alignement absolument parfait sans peine! (Comme certains «grands»...);
— normalement il n'est pas ajustable, mais j'ai trouvé le moyen de le faire bêtement en utilisant les vis de fixation! (Comme certains «grands»...);
— réglage des niveaux horizontaux et verticaux, de facto manuel, et pas ces merdouilles de réglage de niveau automatique, où tu ne sais jamais où tu en es... (Comme certains «grands»...).
— excepté le laser, pas de gadget électronique inutile, futile et casse-tête qui sont des sources de pannes (comme sur certains grands...).
— garantit 3 ans (rare chez les «grands»...)!
Il y a juste la portée un peu faible, mais comme il y a un rétro-éclairage, on peut pafraitement l'utiliser dehors à la tombée de la nuit, mais pour le prix...
dedeleco
x 11
Message non lupar dedeleco » 08/05/12, 21:41
Obamot a écrit :
Le laser n'est pas nécessaire pour voir que la maison descend dans le champ de riz vaseux, et l'essentiel est de stopper l'évolution avant de redresser peu à peu.
Un exposé détaillé sur l'amélioration des sols :
http://www.cours-genie-civil.com/IMG/pd ... s_sols.pdf
L'injection de ciment en profondeur est simple si basse pression et pourrait résoudre le problème.
Ont ils testé le sol avec un pieu ou simple tube de plusieurs mètres, et une une masse de 5 à 10 Kg tapant dessus à la main, pour savoir la profondeur où ce tube s'enfonce sans peine, égale à la profondeur de sol mou ????
Est ce de la tourbe, toute molle ???
Très possible si depuis des millénaires, l'eau séjourne et accumule des déchets végétaux en humus, très bon pour le riz; mais idéal pour avaler une maison.
C'est simple et crucial !!
A mon avis c'est urgent de savoir et d'agir, avant les prochaines inondations .
Les caractéristiques mécaniques des sols sont fonction de la concentration des différentes
phases. Donc après traitement les sols dit grenus on un meilleur comportement mécanique, les
ordres de grandeur suivants sont souvent rencontrés :
• tourbe 0,2 à 0,5 MPa ;
• argile molle (récente) 1 à 5 MPa ;
• argile raide 10 à 50 MPa ;
• sable lâche 5 à 20 MPa ;
• sable dense 100 à 200 MPa
Revenir vers « Econology forum in english »
