Tu as aussi cela: http://h2o0il.com/
Intéressant vers le milieu de page ("316L Stainless Cavitation Info"), ça parle du conditionnement des tubes mais avec le traducteur c'est un peu du chinois pour moi
316L Stainless Cavitation Info.......
In this study, NiTi powder was preplaced on the AISI 316L substrate and melted with a high-power CW Nd:YAG laser....
The cavitation erosion resistance of the modified layer (316-NiTi-Laser) could reach about 29 times that of AISI 316L........
In both the laser-surfaced and TIG-surfaced samples, the superelastic behavior typical of austenitic NiTi was only partially retained and the superior cavitation erosion resistance was thus still not fully attained.
electrostatic excitation of covalent bond energetics causes the destructive catastrophic dissociation to occur!
There is an electrical resonance between the inductors (Resonant Charging Choke coils), there is an electrical resonance within the electrode gap itself within the water,and, finally, there is an acoustical resonance between the cylindrical electrodes, which is somehow phase coupled to the electrical resonances.The electrical resonance involves a phase delay between the pulses to the electrodes, which has the effect of inhibiting current flow into the cell; the acoustic resonance may be producing a standing wave which inhibits ion transport. Both of these contribute to dielectric breakdown in the water, which is where electrons are ripped from the water
Donc cet effet S. Meyer est un cas de fusion froide par cavitation dans l'eau qui a été expérimenté par d'autres méthodes....
Avec le retard à la cavitation, S. Meyer en utilisant un maximum de phénomènes physiques cumulés se place presque en dehors de la physique connue, et mesurable. ....
Pour cette raison il est très difficile de reproduire exactement, et il est essentiel de rassembler un max d'informations sur ce qu'a fait S. Meyer.
Ah... Il me semblait que cette fréquence était "luminosonore"... Ne parle-t-on pas de "sonoluminescence"...elephant a écrit :En fait, finalement, ce qui me manque avant de commencer les choses sérieuses, notamment à la lumière de ces informations est de savoir s'il existe une fréquence sonore ( ou ultrasonore ) à laquelle faire résonner les tubes. Certes, il faut les faire résonner à leur fréquence ou une des harmonique, mais il y a-t-il une fréquence idéale ? Doit elle être harmonique de la 2 e fréquence ?
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 121 invités
