only one atmosphere
Andrew
Remundo a écrit :thank you Andrew
you put regenerator on the first picture and get back the Stirling engine.
inventor a écrit :Here is the thermodynamic problem .. We have in a box, in a vacuum is a set of thermal engines with generators ... Will this set be more efficient than it would be normally installed without a box?
it's about how laws of thermodynamics work on the Equator, and how on the Pole.
Different temperatures
on the Equator 40 degrees Celsius and at the Pole - 40 degrees Celsius also for efficiency and the layout of the engine will be important ...?
Andrew
You'd need a prototype, without it you'd have to do calculations, estimate the potential...Flytox a écrit :How about the specific fuel consumption of this engine (from the video we're talking about)?
Il faudrait un prototype, sans lui il faut faire des calculs, estimer le potentiel...Flytox a écrit :C'est quoi la consommation spécifique de ce moteur (de la vidéo dont on parle) ?
So, if we understand you well, the weak point of your engine is that he’s vulnerable to thermal (climatic) changes in the environment. 60 to 70°C difference is not negligible... As it is, it's still "fun physics" as long as you don't give the said "efficiency" as suggested by Flytox.inventor a écrit :Well, Feliks -Newcomen can also make electricity from a low-temperature heat source !
Well, for example, from geothermal energy, the cooling heat of internal combustion engines, and other industrial sources that can produce this temperature of 70 degrees Celsius .. But as we pump the air out to 1/3 of the atmosphere, the steam will be formed already at a temperature of 70 degrees Celsius. I am cold water, let's say 10 degrees Celsius, and the piston pushed by the force of the
"Inner Atmosphere" will go down, because there will be almost a vacuum .... As we have such energy in abundance, efficiency is in second place ..
And as you can see, the operation of a heat engine does not depend only on temperature, as suggested by the so far known second law of thermodynamics, but also on pressure too ...
Andrew![]()
Revenir vers « Econology forum in english »
