The "FF" engine by SHI ZHE
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
FUHANDAIGOU
GENERETOR
Message non lupar FUHANDAIGOU » 21/06/10, 09:15
Internal combustion engine as a power supply
Generator in rotor. Magnetic pole and rotor permanent connection ,synchronous rotation.Coil fixed.When the rotor rotation, the magnetic induction coil cutting line, producing current.
Advantage of this design:
1, compact structure;
2, the engine starts easily, can use external power supply.
3, can use electronic devices to facilitate control of the engine's ignition timing.
http://www.ipernity.com/home/zheshi?rev=31
En lien avec le team Yves SAUGET, SYCOMOREEN, Pascal HA PHAM
pascal HA PHAM
x 25
nice item
Message non lupar pascal HA PHAM » 21/06/10, 09:27
hi Shi Zhé,
this new version is a nice one, without mécanic-transmission !
I think Yves will also look at your drawing with lot of attention.
Your work is very intéresting.
Friendly
Pascal
FUHANDAIGOU
Message non lupar FUHANDAIGOU » 21/06/10, 14:45
Hi Pascal
On my engine, what do you suggest.you can use French, I have a translation software.thanks.
have a great day!
Friendly!
pascal HA PHAM
x 25
WHY NOT A SMALL PROTOTYPE
Message non lupar pascal HA PHAM » 23/06/10, 07:19
HI Shi Zhé,
now I think you will draw plants for the construction of an early prototype of your FF concept, very small because it will be more economic, it's important to show a real one.
exemple : Using air pressure to turn.
and for the fist simple one, you dont add the full transmission.
It's also our project for a simple type of ZZ (p, c or diabolo) engine.
On the Turbicone sujet (by Yves Sauget) i speak about thèse news concepts engines (FF, ZZ , turbicône and robiplan...) : they have the great spéciality to have the main pièce witch is moving in 3 D ....only few engines give this particularity !
we have to show to the world a fonctionnal
métallic prototype in each of thèse news concepts !
Raymond is full working on a métallic prototype of MPRBC and also a SAERE.
i think now we have to do that !
have a great day
friendly
Pascal
FUHANDAIGOU
Message non lupar FUHANDAIGOU » 29/06/10, 16:22
Hi everyone
New design of machinery, including the new design of the rotor system and the new design of the transmission system
Mechanical structure
rotor system and transmission system
pascal HA PHAM
x 25
OK for your technicals internals news parts
Message non lupar pascal HA PHAM » 29/06/10, 16:49
Hi SHI ZHE,
I am very glad to see your last great internal (s) modification (s),
nice !
your "FF concept" and our "ZZ 2 one" are two pretty brothers (or pretty sisters) !.
it's very sympatic to be in the same technical aréa and also to be in a very good understanding.
I hope Yves Sauget give you a technical thinking .
Have a great day and see you
friendly
pascal
x 7404
Message non lupar Remundo » 29/06/10, 17:35
Hi Zhe,
you have designed again your engine with the same transmission as Yves.
That makes a good result. :idea:
Pascal enjoys it 8)
Bye !
pascal HA PHAM
x 25
animation
Message non lupar pascal HA PHAM » 30/06/10, 09:10
Hi SHI ZHE,
Hi everybody..
yes Raymond : the word of SHI ZHE is nice ans so interesting....it's a similar technic than "ZZ 2" but on this last "FF 2", it's the "fraisoïde ram" witch is moving with two gears equiped .
for SHI ZHE : can you make an animation of this new internal organisation ?
(like a "gif")
...it will be very interesting for the readers to see the ram/piston during his cyclic motion in the chamber.
"Our 5 Men Inventors Team is at his up in this beautifull summer time 2010"
have a great day our friend
pascal
FUHANDAIGOU
Message non lupar FUHANDAIGOU » 01/07/10, 06:59
Hi Pascal and Remaundo
I will soon make an animation.
Have a nice day!
Your friend.
pascal HA PHAM
x 25
animation GIF
Message non lupar pascal HA PHAM » 01/07/10, 09:01
hi SHI ZHE,
It's Yves witch maked all the last animations about ZZ 2 and turbicône :
I am not equiped to do gif animations !
You will try to see that with Yves
nice yours diaporama on IPERNITY =
http://www.ipernity.com/doc/zheshi/show
have a great day my friend
Pascal
Revenir vers « Econology forum in english »
