Risk of Global climate change by BP Oil Spill
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
x 12719
Message non lupar Christophe » 21/12/10, 18:04
RISK OF GLOBAL CLIMATE CHANGE BY BP OIL SPILL
Gianluigi Zangari
Frascati National Laboratories (LNF) - National Institute of Nuclear Physics (INFN)
Frascati 00044, Via E. Fermi, 40, ITALY
Correspondence to: Gianluigi Zangari Email: gianluigi.zangari@lnf.infn.it
Abstract: BP Oil Spill may cause an irreparable damage to the Gulf Stream global climate thermoregulation activity. The Gulf Stream importance in the global climate thermoregulation processes is well assessed. The latest real time satellite (Jason, Topex/Poseidon, Geosat Follow-On, ERS-2, Envisat) data maps of May-June 2010 processed by CCAR1,2 (Colorado Center for Astrodynamics Research), checked at Frascati Laboratories by the means of the SHT congruent calculus3 and compared with past years data, show for the first time a direct evidence of the rapid breaking of the Loop Current, a warm ocean current, crucial part of the Gulf Stream.
As displayed both by the sea surface velocity maps and the sea surface height maps, the Loop Current broke down for the first time around May 18th and generated a clock wise eddy, which is still active (see Fig. 1).
Next: https://www.econologie.info/share/partag ... qAHZnb.pdf
x 7784
Message non lupar Obamot » 21/12/10, 18:34
Intéressant débat, mais n'a-t-on pas déjà relativisé ça? Il me semble qu'il avait été dit que le volume d'eau de l'Atlantique est tellement gigantesque, que la fuite de pétrole était moins que peanut en comparaison.
Les seuls dégâts seraient la biodiversité marine en profondeur (puisque la partie volatile des hydrocarbures s'étant évaporée depuis belle lurette, les parties flotantes ayant été dissoutes par dispersion de solvants (kérosène?) ne resterait plus que cette sorte de "boue résiduelle" plus lourde que l'eau... et ayant coulé à 1000m de profondeur...)
Mais je peux m'éléphanter :mrgreen:
x 12719
Message non lupar Christophe » 21/12/10, 18:41
English speaking here, go here for french similar sujet: https://www.econologie.com/forums/gulf-strea ... 10281.html
:cheesy:
x 7784
Message non lupar Obamot » 21/12/10, 23:07
Oh my goodness ! :oops:
Something's blown out here... :cheesy:
So yes. Relatively few oil spill for the huge water volume of the Atlantic ocean imho.
Until we know that volatil hydrocarbures was already in the air, floating part was dispersed by kerosen solvants and the sticky part sank as deep as (-)1000 meters. The big impact is against biodiversity, but not much affect the "GLOBAL CLIMATE CHANGE" in this aspect.
BTW, is not because we have a two rude winter (one because of el niño) that we have to conclude this...
Do I'm wrong?
x 7846
Message non lupar Remundo » 21/12/10, 23:30
I think our current winter in France is quite normal. But the thermohaline circulation is a very sensitive mechanism and the global warming, that we should call "climate change" more rigorously, may modify the collaps of the water in arctic areas, because huge quantities of soft water decrease the salinity of the oceans there...
Then the thermal regulation, currently granted by the gulf stream, could become weak, or disappear, and the western Europe been frozen while other area been overheated...
P.S. : Be careful Obamot, because I have got the powers of moderator here :cheesy:
Edit : I wish to add here the 2 links of Dedeleco, written in the Shakespeare language :
dedeleco a écrit :Current Global Warming May Reverse Circulation in Atlantic Ocean, as It Did 20,000 Years Ago
http://www.sciencedaily.com/releases/20 ... 141541.htm
Reversed flow of Atlantic deep water during the Last Glacial Maximum
http://www.nature.com/nature/journal/v4 ... e09508.pdf
x 7784
Message non lupar Obamot » 21/12/10, 23:39
Thank's !
Life is good - Blue Skies ! :cheesy:
Revenir vers « Econology forum in english »
