The Vortex Valve is an exceptional solution for engineers looking to precisely control the discharge flow rate from stormwater drainage.
Missing: avec | Show results with:avec
People also ask
How does a vortex valve work?
What is vortex finder in cyclone?
30" high-efficiency dust cyclone with vortex breaker. 25 HP fan available, sold separately. Clean Air Inlet 12". Dirty air involute inlet 11" X 22".
Hydrocyclones are an efficient way to separate slurries. With no moving parts, they depend on the feed pressure, or velocity, into the cyclone.
Vortex Valves. HydroCAD provides direct support for vortex control valves from Hydro International, Mosbaek and Hydrovex.
5 Standard Vortex breaker is designed to disrupt cyclonic flow formation of reject materials (staples, wire, nails, sand, etc) A36 with tungsten carbide coating ...
Oct 1, 2008 · The HYDROVEX® FluidVertic Vertical Vortex Valves are especially applicable in Stormwater and Storm Drain flow control. Some examples of ...
The ESEP vortex flow control consists of a durable, stainless steel (AISI 316) casing with no moving parts. At low flow rates, the vortex flow control allows ...
$1,285.00 In stock
Weight, 3.800 lbs. type. Smoothbore. Outlet Diameter. 1 3/8" (35 mm). Inlet Coupling Style. Rocker. Remote Control. N. Pistol Grip.
Missing: cyclone avec
Vortex Finder. The vortex finder, which provides passage of the clean coal to the overflow stream, extends deep into cylindrical portion to emphasize the ...
Missing: valve avec
