US10836466B2 - Toroidal propeller - Google Patents
Toroidal propeller Download PDF
Info
Publication number
US10836466B2
US10836466B2 US15/803,961 US201715803961A US10836466B2 US 10836466 B2 US10836466 B2 US 10836466B2 US 201715803961 A US201715803961 A US 201715803961A US 10836466 B2 US10836466 B2 US 10836466B2
Authority
US
United States
Prior art keywords
propeller
elongate
toroidal
elements
tip
Prior art date
Legal status (The legal status is an assumption and is not a legal conclusion. Google has not performed a legal analysis and makes no representation as to the accuracy of the status listed.)
Active
Application number
US15/803,961
Other versions
US20190135410A1 (en
Inventor
Thomas Sebastian
Christopher Strem
Current Assignee (The listed assignees may be inaccurate. Google has not performed a legal analysis and makes no representation or warranty as to the accuracy of the list.)
Massachusetts Institute of Technology
Original Assignee
Priority date (The priority date is an assumption and is not a legal conclusion. Google has not performed a legal analysis and makes no representation as to the accuracy of the date listed.)
Filing date
Publication date
Application filed by Massachusetts Institute of Technology filed Critical Massachusetts Institute of Technology
Priority to US15/803,961 priority Critical patent/US10836466B2/en
Priority to PCT/US2018/059288 priority patent/WO2019156724A1/en
Publication of US20190135410A1 publication Critical patent/US20190135410A1/en
Assigned to MASSACHUSETTS INSTITUTE OF TECHNOLOGY reassignment MASSACHUSETTS INSTITUTE OF TECHNOLOGY ASSIGNMENT OF ASSIGNORS INTEREST (SEE DOCUMENT FOR DETAILS). Assignors: STREM, CHRISTOPHER, SEBASTIAN, THOMAS
Application granted granted Critical
Publication of US10836466B2 publication Critical patent/US10836466B2/en
Active legal-status Critical Current
Anticipated expiration legal-status Critical
Links
Images
Classifications
    • BPERFORMING OPERATIONS; TRANSPORTING
    • B64AIRCRAFT; AVIATION; COSMONAUTICS
    • B64CAEROPLANES; HELICOPTERS
    • B64C11/00Propellers, e.g. of ducted type; Features common to propellers and rotors for rotorcraft
    • B64C11/16Blades
    • B64C11/18Aerodynamic features
    • B64C11/008Propellers, e.g. of ducted type; Features common to propellers and rotors for rotorcraft characterised by vibration absorbing or balancing means
    • B64C11/005Spiral-shaped propellers
    • B64C11/16Blades
    • B64C11/20Constructional features
    • FMECHANICAL ENGINEERING; LIGHTING; HEATING; WEAPONS; BLASTING
    • F01MACHINES OR ENGINES IN GENERAL; ENGINE PLANTS IN GENERAL; STEAM ENGINES
    • F01DNON-POSITIVE DISPLACEMENT MACHINES OR ENGINES, e.g. STEAM TURBINES
    • F01D5/00Blades; Blade-carrying members; Heating, heat-insulating, cooling or antivibration means on the blades or the members
    • F01D5/12Blades
    • F01D5/14Form or construction
    • F01D5/141Shape, i.e. outer, aerodynamic form
    • F01D5/12Blades
    • F01D5/147Construction, i.e. structural features, e.g. of weight-saving hollow blades
    • F01D5/12Blades
    • F01D5/16Form or construction for counteracting blade vibration
    • B64C11/02Hub construction
    • B64C2201/108
    • B64C2201/162
    • B64C39/00Aircraft not otherwise provided for
    • B64C39/02Aircraft not otherwise provided for characterised by special use
    • B64C39/024Aircraft not otherwise provided for characterised by special use of the remote controlled vehicle type, i.e. RPV
    • B64UUNMANNED AERIAL VEHICLES [UAV]; EQUIPMENT THEREFOR
    • B64U30/00Means for producing lift; Empennages; Arrangements thereof
    • B64U30/20Rotors; Rotor supports
    • B64U50/00Propulsion; Power supply
    • B64U50/10Propulsion
    • B64U50/13Propulsion using external fans or propellers
    • B64U50/14Propulsion using external fans or propellers ducted or shrouded
    • F05INDEXING SCHEMES RELATING TO ENGINES OR PUMPS IN VARIOUS SUBCLASSES OF CLASSES F01-F04
    • F05DINDEXING SCHEME FOR ASPECTS RELATING TO NON-POSITIVE-DISPLACEMENT MACHINES OR ENGINES, GAS-TURBINES OR JET-PROPULSION PLANTS
    • F05D2240/00Components
    • F05D2240/20Rotors
    • F05D2240/30Characteristics of rotor blades, i.e. of any element transforming dynamic fluid energy to or from rotational energy and being attached to a rotor
    • F05D2240/307Characteristics of rotor blades, i.e. of any element transforming dynamic fluid energy to or from rotational energy and being attached to a rotor related to the tip of a rotor blade
Definitions
  • This invention relates to a toroidal propeller having higher thrust per unit power along with a significant reduction in acoustic signature than is achievable with conventional propeller designs.
  • Multirotor drones rely entirely on the thrust generated by propellers both to stay aloft and to maneuver.
  • the mechanical simplicity of these platforms drives their adoption in the commercial sector for a range of applications—cinematography, industrial inspection, airborne monitoring, aerial delivery, and even air taxis.
  • recent psychoacoustic experiments conducted by NASA Langley on human test subjects shows that while overall annoyance to noise increases with sound level, small multirotor drones generate a high annoyance level at a given sound level than do road vehicles. See FIG. 1 that compares a time integrated A-weighted sound energy metric to perceived annoyance.
  • the primary noise sources for these multirotor drones are brushless DC motors and the aerodynamic noise generated by the propellers driven by those motors.
  • Public acceptance of multirotor drones is critical to their widespread use; acoustically quieter propeller designs that are able to serve as drop-in replacements for conventional propellers may, more than any other technological advancement, accelerate the acceptance and wide use of drones in public spaces.
  • FIG. 3 a is a design disclosed in U.S. Pat. No. 4,445,817.
  • FIG. 3 b is a shrouded propeller design from U.S. Pat. No. 5,096,382.
  • FIG. 3 c described in U.S. Pat. No. 6,736,600, is somewhat similar to the design disclosed in this patent application.
  • the design in FIG. 3 c utilizes a split propeller design wherein each blade is split at an arbitrary distance from the main propeller hub and extended forward and aft with respect to the propeller rotation direction.
  • the toroidal propeller of the invention includes a hub supporting a plurality of elongate propeller elements in which a tip of a leading propeller element curves into contact with a trailing propeller element to form a closed structure with increased stiffness and reduced acoustic signature.
  • a preferred embodiment includes two or more propeller elements, with number of elements dictated by desired propeller responsiveness, propeller diameter, and material properties.
  • FIG. 1 is a graph of mean annoyance rating against sound exposure level, A-weighted.
  • FIG. 2 a is a perspective view of a planar and a ring wing.
  • FIG. 2 b is a graph of lift-to-drag ratio with respect to angle of attack for a straight and a ring structure.
  • FIGS. 3 a , 3 b and 3 c are prior art propeller designs.
  • FIG. 4 a - FIG. 4 f illustrate variations on three-bladed toroidal propeller geometry according to the invention along with conventional comparable (twist distribution) propellers for comparison.
  • FIG. 5 a is a perspective view of a conventional propeller.
  • FIG. 5 b is a perspective view of an embodiment of a toroidal propeller disclosed herein.
  • FIG. 6 is a graph of thrust coefficient against power coefficient for tested toroidal and conventional propellers.
  • FIG. 7 is a graph of sound level against thrust coefficient for tested toroidal and conventional propellers.
  • FIG. 8 is a graph showing the relationship between audiograms of humans and house mice and the frequency ranges of their vocalizations.
  • FIG. 9 is a graph of power against frequency for tested conventional and toroidal propellers.
  • the disclosed toroidal propeller is an extension of a non-planar box wing with the tip of each curved propeller element extending into each trailing propeller element. This design allows for a more manufacturable design while improving overall aerodynamic performance and reducing acoustic signature.
  • Variations on a three-bladed toroidal propeller were designed and fabricated using additive manufacturing techniques along with corresponding (i.e., utilizing the same airfoil cross section and twist distribution, number of propeller elements, and propeller diameter) conventional propellers designed and fabricated as well as shown in FIGS. 4 a - 4 f.
  • a computer-controlled dynamometer shown in FIGS. 5 a and 5 b was used to run each of the propellers, collecting torque, thrust and power measurements as a function of propeller speed.
  • a sound meter and microphone were used to collect acoustic response data.
  • FIG. 6 illustrates the relative performance of each of the propeller designs with the highest performing toroidal propeller (B160) demonstrating higher efficiencies than the best performing conventional propeller (SG30).
  • FIG. 7 shows the best toroidal propeller design generating higher thrust at a given sound level than the test conventional design.
  • the frequency content of the noise generated by propellers is critical to assessing their psychoacoustic impact. While the frequency range of human hearing is often quoted as between 20 Hz-20 kHz, the threshold of hearing is a function of tone frequency as shown in the audiogram in FIG. 8 . This plot shows that humans are particularly sensitive to tones between 1-5 kHz. It also shows that there is a significant drop-off in audibility as frequency increases.
  • FIG. 9 compares audio signal power spectral density (PSD) of the best performing toroidal and conventional propellers.
  • PSD audio signal power spectral density
  • a potential toroidal propeller market extends throughout the entire small multirotor drone industry and enables new use cases not before viable due to the noise generated by these platforms.
  • the closed form propeller design of the invention increases its overall structural stiffness and enables reliable fabrication using additive manufacturing techniques thereby allowing for drop-in replaceability with conventional propellers in use on various multirotor drone models and types.
Abstract
The propeller includes a hub supporting a plurality of elongate propeller elements in which a tip of a leading propeller element curves into contact with a trailing propeller element to form a closed structure with increased stiffness and reduced acoustic signature.
Description
This invention was made with Government support, under Contract No. FA8702-15-D-0001 awarded by the US Air Force. The government has certain rights in the invention.
BACKGROUND OF THE INVENTION
Multirotor drones rely entirely on the thrust generated by propellers both to stay aloft and to maneuver. The mechanical simplicity of these platforms drives their adoption in the commercial sector for a range of applications—cinematography, industrial inspection, airborne monitoring, aerial delivery, and even air taxis. However, recent psychoacoustic experiments conducted by NASA Langley on human test subjects shows that while overall annoyance to noise increases with sound level, small multirotor drones generate a high annoyance level at a given sound level than do road vehicles. See FIG. 1 that compares a time integrated A-weighted sound energy metric to perceived annoyance.
The primary noise sources for these multirotor drones are brushless DC motors and the aerodynamic noise generated by the propellers driven by those motors. Public acceptance of multirotor drones is critical to their widespread use; acoustically quieter propeller designs that are able to serve as drop-in replacements for conventional propellers may, more than any other technological advancement, accelerate the acceptance and wide use of drones in public spaces.
Closed form or box wings have been investigated in the past as a method to reduce losses associated with tip vortex generation while also enhancing the structural integrity of the wing. Investigators at the Massachusetts Institute of Technology Lincoln Laboratory have studied the aerodynamic feasibility of so-called ring wings, wherein the tips of two lifting surfaces are linked via a lofted surface to generate a non-planar closed structure. This research demonstrated lift-to-drag ratio improvements of a ring wing relative to a comparable planar wing of 40-60% as shown in FIGS. 2a and 2b derived from interactions between lifting surfaces and a significant reduction in the strength of the trailing tip vortex, a key source of aerodynamic noise.
With reference now to FIGS. 3a, 3b and 3c , example prior art propellers are shown. FIG. 3a is a design disclosed in U.S. Pat. No. 4,445,817. FIG. 3b is a shrouded propeller design from U.S. Pat. No. 5,096,382. FIG. 3c , described in U.S. Pat. No. 6,736,600, is somewhat similar to the design disclosed in this patent application. The design in FIG. 3c utilizes a split propeller design wherein each blade is split at an arbitrary distance from the main propeller hub and extended forward and aft with respect to the propeller rotation direction.
SUMMARY OF THE INVENTION
The toroidal propeller of the invention includes a hub supporting a plurality of elongate propeller elements in which a tip of a leading propeller element curves into contact with a trailing propeller element to form a closed structure with increased stiffness and reduced acoustic signature. A preferred embodiment includes two or more propeller elements, with number of elements dictated by desired propeller responsiveness, propeller diameter, and material properties.
BRIEF DESCRIPTION OF THE DRAWING
FIG. 2a is a perspective view of a planar and a ring wing.
FIG. 2b is a graph of lift-to-drag ratio with respect to angle of attack for a straight and a ring structure.
FIGS. 3a, 3b and 3c are prior art propeller designs.
FIG. 4a -FIG. 4f illustrate variations on three-bladed toroidal propeller geometry according to the invention along with conventional comparable (twist distribution) propellers for comparison.
FIG. 5a is a perspective view of a conventional propeller.
FIG. 5b is a perspective view of an embodiment of a toroidal propeller disclosed herein.
DESCRIPTION OF THE PREFERRED EMBODIMENT
The disclosed toroidal propeller is an extension of a non-planar box wing with the tip of each curved propeller element extending into each trailing propeller element. This design allows for a more manufacturable design while improving overall aerodynamic performance and reducing acoustic signature.
Variations on a three-bladed toroidal propeller were designed and fabricated using additive manufacturing techniques along with corresponding (i.e., utilizing the same airfoil cross section and twist distribution, number of propeller elements, and propeller diameter) conventional propellers designed and fabricated as well as shown in FIGS. 4a -4 f.
A computer-controlled dynamometer shown in FIGS. 5a and 5b was used to run each of the propellers, collecting torque, thrust and power measurements as a function of propeller speed. A sound meter and microphone were used to collect acoustic response data.
To facilitate direct comparison between each of the propellers, the measured data were non-dimensionalized and recomputed as thrust (generated), torque (required), and power (required) coefficients. FIG. 6 illustrates the relative performance of each of the propeller designs with the highest performing toroidal propeller (B160) demonstrating higher efficiencies than the best performing conventional propeller (SG30).
A similar trend appears when assessing acoustic performance. FIG. 7 shows the best toroidal propeller design generating higher thrust at a given sound level than the test conventional design.
The frequency content of the noise generated by propellers is critical to assessing their psychoacoustic impact. While the frequency range of human hearing is often quoted as between 20 Hz-20 kHz, the threshold of hearing is a function of tone frequency as shown in the audiogram in FIG. 8. This plot shows that humans are particularly sensitive to tones between 1-5 kHz. It also shows that there is a significant drop-off in audibility as frequency increases.
FIG. 9 compares audio signal power spectral density (PSD) of the best performing toroidal and conventional propellers. The acoustic signature of the toroidal propeller of the invention is lower than a conventional propeller across a wide range of frequencies, but more critically, it is significantly lower in the 1-5 kHz range that humans are most sensitive to. Note that this result was achieved without any attempt at optimization or tailoring. Those of ordinary skill in the art will recognize that additional tuning of the propeller material, diameter, number of elements, airfoil cross section, spanwise sweep, and twist distribution may yield additional improvements possibly shifting some fraction of the acoustic energy into higher, less perceptible, frequencies.
A potential toroidal propeller market extends throughout the entire small multirotor drone industry and enables new use cases not before viable due to the noise generated by these platforms. The closed form propeller design of the invention increases its overall structural stiffness and enables reliable fabrication using additive manufacturing techniques thereby allowing for drop-in replaceability with conventional propellers in use on various multirotor drone models and types.
It is recognized that modifications and variations of the present invention will be apparent to those of ordinary skill in the art and all such modifications and variations are included within the scope of the appended claims.
Claims (12)
What is claimed is:
1. Toroidal propeller comprising:
2. The toroidal propeller of claim 1 having two or more propeller elements.
3. The toroidal propeller of claim 1, wherein the plurality of elongate propeller elements comprises three elongate propeller elements.
4. Toroidal propeller comprising:
a hub supporting a plurality of elongate propeller elements in which a terminal end tip of a leading propeller element curves into contact with a trailing propeller element to form a closed structure with increased stiffness and reduced acoustic signature, with a terminal end of the trailing propeller element curving into contact with the hub.
5. The toroidal propeller of claim 4 having two or more propeller elements.
6. The toroidal propeller of claim 4, wherein the plurality of elongate propeller elements comprises three elongate propeller elements.
7. Toroidal propeller comprising:
a hub supporting a plurality of elongate propeller elements in which a tip of a leading propeller element of a first elongate propeller element of the plurality of elongate propeller elements curves into contact with a trailing propeller element of a second elongate propeller element of the plurality of elongate propeller elements, the second elongate propeller element being an adjacent elongate propeller element to the first elongate propeller element, to form a closed structure with increased stiffness and reduced acoustic signature,
wherein an initiation location at which the tip of the leading propeller element is initiated is at a different location than a termination location at which a tip of the trailing propeller element terminates.
8. The toroidal propeller of claim 7 having two or more propeller elements.
9. The toroidal propeller of claim 7, wherein the plurality of elongate propeller elements comprises three elongate propeller elements.
10. Toroidal propeller comprising:
a hub supporting a plurality of elongate propeller elements, each elongate propeller element having a first terminal end that extends from the elongate propeller element adjacent thereto and a second terminal end that extends from the hub in which a tip of a leading propeller element curves into contact with a trailing propeller element to form a closed structure with increased stiffness and reduced acoustic signature.
11. The toroidal propeller of claim 10 having two or more propeller elements.
12. The toroidal propeller of claim 10, wherein the plurality of elongate propeller elements comprises three elongate propeller elements.
US15/803,961 2017-11-06 2017-11-06 Toroidal propeller Active US10836466B2 (en)
Priority Applications (2)
Application Number Priority Date Filing Date Title
US15/803,961 US10836466B2 (en) 2017-11-06 2017-11-06 Toroidal propeller
PCT/US2018/059288 WO2019156724A1 (en) 2017-11-06 2018-11-05 Toroidal propeller
Applications Claiming Priority (1)
Publications (2)
Publication Number Publication Date
US20190135410A1 US20190135410A1 (en) 2019-05-09
US10836466B2 true US10836466B2 (en) 2020-11-17
Family
ID=66326794
Family Applications (1)
Application Number Title Priority Date Filing Date
US15/803,961 Active US10836466B2 (en) 2017-11-06 2017-11-06 Toroidal propeller
Country Status (2)
Country Link
US (1) US10836466B2 (en)
WO (1) WO2019156724A1 (en)
Cited By (2)
* Cited by examiner, † Cited by third party
Publication number Priority date Publication date Assignee Title
US11203413B2 (en) 2018-11-07 2021-12-21 N99 Llc Advanced propeller assemblies
EP4316978A1 (en) * 2023-04-17 2024-02-07 Alpraaz AB Variable toroidal propeller
Citations (6)
US4445817A (en) 1981-08-06 1984-05-01 Wethern Richard J Propeller construction
US4973225A (en) * 1988-09-28 1990-11-27 Claus Kruppa Adjustable propeller
US5096382A (en) 1989-05-17 1992-03-17 Gratzer Louis B Ring-shrouded propeller
US6736600B1 (en) * 1999-07-06 2004-05-18 Rudolf Bannasch Rotor with a split rotor blade
US20140161622A1 (en) 2012-12-10 2014-06-12 Gregory Charles Sharrow Propeller
US9926058B2 (en) 2012-12-10 2018-03-27 Sharrow Engineering Llc Propeller
Patent Citations (9)
US20170218772A1 (en) 2012-12-10 2017-08-03 Sharrow Engineering, LLC Propeller
US20180186439A1 (en) 2012-12-10 2018-07-05 Sharrow Engineering Llc Propeller
US20180237122A1 (en) 2012-12-10 2018-08-23 Sharrow Engineering Llc Propeller
Non-Patent Citations (2)
Title
Christian, A., et al., "Initial investigation into the psychoacoustic properties of small unmanned aerial system noise," presented at 17th AIAA Aviation Technology, Integration, and Operations Conference (Aviation 2017); Jun. 5-9, 2017; Denver, CO; United States <https://ntrs.nasa.gov/search.jsp?R=20170005870> pp. 1-21.
Ehret, G., "Age-dependent hearing loss in normal hearing mice," Naturwissenschaften, Nov. 1974, vol. 61, Issue 11, pp. 506-507.
Cited By (2)
Also Published As
Publication number Publication date
WO2019156724A1 (en) 2019-08-15
Similar Documents
Publication Publication Date Title
KR101713264B1 (en) A blade for a helicopter anti-torque device
US9341158B2 (en) Quiet wind turbine blade
CN106795863B (en) Structure with the rigid projection for being suitable for crossing fluid environment
US10836466B2 (en) Toroidal propeller
Paruchuri et al. Leading edge serration geometries for significantly enhanced leading edge noise reductions
US20110150664A1 (en) Aeroacoustic rotor blade for a wind turbine, and wind turbine equipped therewith
US20210079883A1 (en) Noise Reduction Surface Treatment for Airfoil
KR101051575B1 (en) Tip airfoil on blade for 2 megawatt wind generator
Lee et al. Quieter propeller with serrated trailing edge
JP5425192B2 (en) Propeller fan
Biedermann et al. Optimised test rig for measurements of aerodynamic and aeroacoustic performance of leading edge serrations in low-speed fan application
Kloet et al. Drone on: A preliminary investigation of the acoustic impact of unmanned aircraft systems (UAS)
Collins Boundary-layer control on wings using sound and leading-edge serrations
Baskaran et al. Aerodynamic and aeroacoustic characteristics of propellers with different blade numbers
Moreau et al. Surface curvature effects on the tonal noise of a wall-mounted finite airfoil
Yauwenas et al. The effect of inflow disturbance on drone propeller noise
JP2012092662A (en) Wind-turbine blade, wind power generator equipped with the same, and design method for the same
US20190389128A1 (en) Rotor blade
CN107489650A (en) A kind of axial flow blower
US885109A (en) Screw-propeller.
Pearson et al. Experimental characterization of vertical-axis wind turbine noise
EP3786444B1 (en) Wind turbine blade apparatus
JP2015042864A (en) Blade and wind turbine for wind power generation
EP3879092A1 (en) Hybrid airfoil
JP2019529844A (en) Aerodynamic adjustment of air screw blades, fan turbine blades and wind turbine blades with holes and / or notches and / or notches
Legal Events
Date Code Title Description
FEPP Fee payment procedure
Free format text: ENTITY STATUS SET TO UNDISCOUNTED (ORIGINAL EVENT CODE: BIG.); ENTITY STATUS OF PATENT OWNER: SMALL ENTITY
Free format text: ENTITY STATUS SET TO SMALL (ORIGINAL EVENT CODE: SMAL); ENTITY STATUS OF PATENT OWNER: SMALL ENTITY
STPP Information on status: patent application and granting procedure in general
Free format text: NOTICE OF ALLOWANCE MAILED -- APPLICATION RECEIVED IN OFFICE OF PUBLICATIONS
AS Assignment
Owner name: MASSACHUSETTS INSTITUTE OF TECHNOLOGY, MASSACHUSET
Free format text: ASSIGNMENT OF ASSIGNORS INTEREST;ASSIGNORS:STREM, CHRISTOPHER;SEBASTIAN, THOMAS;SIGNING DATES FROM 20190511 TO 20190513;REEL/FRAME:049159/0425
Owner name: MASSACHUSETTS INSTITUTE OF TECHNOLOGY, MASSACHUSETTS
Free format text: PUBLICATIONS -- ISSUE FEE PAYMENT VERIFIED
STCF Information on status: patent grant
Free format text: PATENTED CASE
Free format text: DOCKETED NEW CASE - READY FOR EXAMINATION
Free format text: PUBLICATIONS -- ISSUE FEE PAYMENT RECEIVED
Free format text: NON FINAL ACTION MAILED
Free format text: RESPONSE TO NON-FINAL OFFICE ACTION ENTERED AND FORWARDED TO EXAMINER
