• Csp Solar Concentrator Solar Power Parabolic Trough
Certification: ISO
Concentrating: Yes
Working Temperature Range: High Temperature
Type: Parabolic Trough Solar Collector
Application: Water Heater, Solar Thermal, Air Conditioning System, Csp
Pipe Material: Glass-to-Metal
Samples:
US$ 1160/Piece 1 Piece(Min.Order)
| Request Sample
Customization:
Diamond Member Since 2016
Suppliers with verified business licenses
Rating: 4.8/5
Trading Company
Basic Info.
Model NO.
PT-20
Open Distance
2.55m
Height
2.5m
Receiver Tube
2m
Module Length
6m
Reflective Surface of 1 Module
15.3sqm
Focal Length
0.75/0.85m
Power of 1 Module
3440kcal/Hr
Tracking Accuracy
Less Than 2mrad
Reflective Mirror Tolerance
Less Than 3mrad
Life Span
20 Years
Transport Package
Cartons and Wooden Cases
Specification
2.55*6
Trademark
Gaia / OEM
Origin
Dezhou, Shandong
Production Capacity
10 Sets / Day
Product Description
CSP solar concentrator solar power parabolic trough
PT-20:
Parabolic trough solar system has the characteristics and advantages of mature technology, environmental protection, regulation of output, can be large-scale sustainable development with low cost, achieving that using focusing mirror field instead of conventional fossil energy sources such as coal-fired boiler, the whole technological process and control mode highly mature and reliable, wide prospect of market.
Main Equipment:
Parabolic trough solar collector is mainly composed of concentrated part, transmission system, heating unit and control system, adopts columnar parabolic design, tracking the sun through parabolic trough concentrate collector, make direct sunlight gathered in receiver tube surface, to heat the heat-transfer fluid, and then in thermodynamic cycle system. In the thermodynamic system, Parabolic trough concentrating collectors are connected by way of series and parallel, and through the modular layout form collection hot field.
 Adopts north-south horizontal axis design, effectively improve the collector heat gains. Ultralimit mechanical structure design, collector can achieve wind speed ≤ 7m/s, tracking precision is 0.1°; Gust wind speed in any state ≤ 20m/s, collector is not damaged. Stop protecting state, down wind speed ≤ 32m/s, collector is not damaged
Our Service:
Our professional technical team can provide system design according to your detailed request.
Can provide whole system, including tracking system, device system, Corrugated hoses.
We can provide installation guide.
Welcome to enquiry! And look forward to the further technical communication with you!
Send your message to this supplier
*To:
*Message:
Enter between 20 to 4,000 characters.
This is not what you are looking for? Post a Sourcing Request Now
You Might Also Like
Rating: 4.8/5
Trading Company
Terms of Payment
LC, T/T, D/P, Western Union
OEM/ODM Availability
Yes
