Redoutable-class submarine (1967)
From Wikipedia, the free encyclopedia
Le Redoutable
Class overview
NameLe Redoutable class
BuildersDCNS
Operators French Navy
Preceded byGymnote
Succeeded byTriomphant class
Built1964–1985
In commission1971–2008
Completed6
Retired6
Preserved1
General characteristics
TypeBallistic missile submarine
Displacement8,000 tons (submerged)
Length128 m (419 ft 11 in)
Beam10.6 m (34 ft 9 in)
Draught10 m (32 ft 10 in)
Propulsion
  • One PWR
  • 16,000 shp (12,000 kW), HEU <= 90%[1]
SpeedOver 20 knots (37 km/h; 23 mph)
RangeUnlimited distance; 20–25 years
Complement
  • 15 officers
  • 120 sailors
Sensors and
processing systems
  • 1 DRUA 33
  • 1 DMUX 21
  • 1 DSUV 61B VLF
  • 1 DUUX 5
  • ARUR 12 radar detector
Armament
  • 16 × M4 MSBS (Mer-Sol Balistique Stratégique) nuclear missiles
  • 4 × 533 mm (21 in) torpedo tubes
  • F-17 and L-5 torpedoes
  • SM-39 Exocet anti-ship missile
The Le Redoutable-class submarine was a ballistic missile submarine class of the French Navy (Marine Nationale). In French, the type is called Sous-marin Nucléaire Lanceur d'Engins (SNLE), literally "Missile-launching nuclear submarine". When commissioned, they constituted the strategic part of the naval component of the French nuclear triad, then called Force de frappe (the aircraft carriers Clemenceau and Foch constituting the tactical part).
The class entered active service in 1971 with Redoutable, six submarines were built in total. All have since been decommissioned. The structural changes in Inflexible have seen it regarded as a different class from the early boats. The class has been superseded by the Triomphant class.
Background[edit]
With the election of Charles de Gaulle as president of France, the French Armed Forces saw a change in direction. Under the new government, French forces were withdrawn from NATO formations due to French unhappiness with American domination of the group. Beginning in the 1960s, French foreign policy would be reshaped to create independence from both of the major opponents of the Cold War, the United States and the Soviet Union. This was later defined in the mantra "to deter – to intervene – to defend". From the foreign policy arose the concept of submarine-based "Force de Dissuassion", with emphasis on the "to deter", which was the focus of new French naval spending.[2]
The new nuclear-powered, nuclear-armed submarine force was planned to be of similar size to the British Royal Navy. However, unlike the British, the French received no support from other nations and the French nuclear program began with a lack of technological expertise to draw from. Furthermore, the Americans refused to provide the French Navy with enriched uranium for the creation of a nuclear reactor.[2] Nevertheless, the project was authorized in 1963.[3] The French Navy resorted to working in conjunction with the civil French Alternative Energies and Atomic Energy Commission (French: Commissariat à l'énergie atomique et aux énergies alternatives), which the US allowed to acquire enriched uranium for experimental land use. A nuclear plant was constructed on land at Cadarache and the reactor was tested to simulate nuclear-powered submarine patrols.[2] Other developments made by the groups working on the project include the development of high-tensile steel by France and the adaption of the submarine hull to nuclear propulsion.[4]
At the same time as the French were developing nuclear propulsion, they were also researching ballistic missiles and nuclear warheads. Caissons were constructed to test fire missiles and by 1967, the submarine Gymnote was fitted with the guidance and navigation systems to be tested. The first ballistic missile launch was at the Landes Trials Centre (French: Centre d'Essais des Landes) at the end of 1968 and nuclear warheads were tested at Moruroa in the Pacific Ocean.[2]
Description[edit]
Comparison of different nuclear systems: left, the SNLE (Redoutable type) with the M4 missile; right, the SNLE-NG (Triomphant type) with the present M45 missile and the future M51 missile.
Designated Sous-marin Nucléaire Lanceur d'Engins (SNLE) literally "Missile-launching nuclear submarine", the design initially measured 128 metres (419 ft 11 in) long overall with a beam of 10.6 metres (34 ft 9 in) and a draught of 10 metres (32 ft 10 in). The submarines initially displaced 7,500 tonnes (7,400 long tons) surfaced and 9,000 tonnes (8,900 long tons) submerged.[5] This later increased to 8,000 tonnes (7,900 long tons) surfaced.[6] The submarines were powered by one pressurised water reactor providing steam to two turbines and two alternators and turning one propeller via a turbo reduction drive creating 12,100 kilowatts (16,200 hp). The submarines also sported electric emergency propulsion capable of providing a range of 5,000 nautical miles (9,300 km; 5,800 mi). The vessels could dive more than 200 metres (660 ft) and had a maximum speed of 20 knots (37 km/h; 23 mph). Each boat had two twin crews comprising 15 officers and 120 men.[7]
Armament[edit]
The Redoutable class all have 16 compartments for submarine-launched ballistic missiles. Redoutable initially deployed with 16 the M1 MSBS (Mer-Sol Balistique Stratégique). The M1 missile was a two stage ballistic missile with a 10.4 m (34 ft 1 in) height and each missile weighed 18,000 kg (40,000 lb). The M1 had a 400-kiloton warhead and an approximate 2,500 km (1,600 mi) range. Terrible was also constructed to carry this missile. The design of Foudroyant was altered to carry the improved M2 MSBS missile in 1974. The M2 was heavier at 19,800 kg (43,700 lb), had a 500-kiloton warhead and a longer range than the M1. In 1977, both the M1 and M2 were replaced by the M20 MSBS.[8]
Vessels in class[edit]
Redoutable class construction data[9]
Number Name Laid down Launched Completed Fate Notes
S611 Redoutable 30 March 1964 29 March 1967 1 December 1971 Stricken December 1991 Museum ship
S612 Terrible 24 June 1967 12 December 1969 1 January 1973 1996
S610 Foudroyant 12 December 1969 4 December 1971 6 July 1974 1998 first M2 submarine
S613 Indomptable 4 December 1971 17 August 1974 23 December 1976 2003
S614 Tonnant October 1974 17 September 1977 3 April 1980 December 1999
S615 Inflexible 27 March 1980 23 June 1982 1 April 1985 2008 first M4 submarine
Service history[edit]
The first submarine, Redoutable, was ordered in 1963, built at Cherbourg, launched in 1967 and commissioned in 1971. This was replaced by the M2 MSBS beginning in 1974, which was in turn replaced by the M20 MSBS beginning in 1977. All except Redoutable were heavily upgraded from 1985 to fire the second generation MIRV capable M4 missile – Tonnant was recommissioned in 1987; Indomptable in 1989; Terrible in 1990; and Foudroyant in 1993.
Redoutable in Cherbourg
Redoutable has been preserved since 2002 as a museum ship at the Cité de la Mer naval museum in Cherbourg-Octeville, France. The reactor compartment has been replaced by a new section.[10]
See also[edit]
Citations[edit]
  1. ^ Lobner, Peter (August 2015). "60 Years of Marine Nuclear Power 1955–2015" (PDF). Retrieved 21 May 2022.[unreliable source?]
  2. ^ a b c d Gardiner, Chumbley & Budzbon 1995, p. 96.
  3. ^ Couhat 1986, p. 90.
  4. ^ Gardiner, Chumbley & Budzbon 1995, p. 123.
  5. ^ Blackman 1972, p. 103.
  6. ^ Couhat 1986, p. 120.
  7. ^ Couhat 1986, p. 96.
  8. ^ Couhat 1986, p. 76.
  9. ^ Gardiner, Chumbley & Budzbon 1995, pp. 122–123.
  10. ^ "À BORD DU SOUS-MARIN LE REDOUTABLE". Cite de la Mer (in French).
References[edit]
  • Blackman, Raymond V. B., ed. (1972). Jane's Fighting Ships 1972–73. London: Sampson Low, Marston & Company. OCLC 28197951.
  • Couhat, Jean Labayle, ed. (1986). Combat Fleets of the World 1986/87. Annapolis, Maryland: Naval Institute Press. ISBN 0-85368-860-5.
  • Gardiner, Robert; Chumbley, Stephen & Budzbon, Przemysław, eds. (1995). Conway's All the World's Fighting Ships 1947–1995. Annapolis, Maryland: Naval Institute Press. ISBN 1-55750-132-7.
  • Miller, David (1982). O'Neill, Richard (ed.). An Illustrated Guide to Modern Submarines. Arco. ISBN 0-66805-495-6.
