US801182A - Rotary engine. - Google Patents
Rotary engine. Download PDFInfo
- Publication number
- US801182A US801182A US26709105A US1905267091A US801182A US 801182 A US801182 A US 801182A US 26709105 A US26709105 A US 26709105A US 1905267091 A US1905267091 A US 1905267091A US 801182 A US801182 A US 801182A
- Authority
- US
- United States
- Prior art keywords
- bands
- plates
- engine
- spiral
- steam
- Prior art date
- Legal status (The legal status is an assumption and is not a legal conclusion. Google has not performed a legal analysis and makes no representation as to the accuracy of the status listed.)
- Expired - Lifetime
Links
- 239000012530 fluid Substances 0.000 description 6
- 230000012447 hatching Effects 0.000 description 3
- 230000005540 biological transmission Effects 0.000 description 1
- 238000010276 construction Methods 0.000 description 1
- 238000010586 diagram Methods 0.000 description 1
- 238000006073 displacement reaction Methods 0.000 description 1
- 238000005498 polishing Methods 0.000 description 1
- 230000035939 shock Effects 0.000 description 1
Images
Classifications
- F—MECHANICAL ENGINEERING; LIGHTING; HEATING; WEAPONS; BLASTING
- F01—MACHINES OR ENGINES IN GENERAL; ENGINE PLANTS IN GENERAL; STEAM ENGINES
- F01C—ROTARY-PISTON OR OSCILLATING-PISTON MACHINES OR ENGINES
- F01C1/00—Rotary-piston machines or engines
- F01C1/02—Rotary-piston machines or engines of arcuate-engagement type, i.e. with circular translatory movement of co-operating members, each member having the same number of teeth or tooth-equivalents
- F01C1/0207—Rotary-piston machines or engines of arcuate-engagement type, i.e. with circular translatory movement of co-operating members, each member having the same number of teeth or tooth-equivalents both members having co-operating elements in spiral form
- F01C1/023—Rotary-piston machines or engines of arcuate-engagement type, i.e. with circular translatory movement of co-operating members, each member having the same number of teeth or tooth-equivalents both members having co-operating elements in spiral form where both members are moving
Definitions
- SHEETS-SHEET 1 llu PATENTED' 001. 3, 1905 L. OREUX.
- the present invention relates to a rotary engine designed to be operated by an elastic fluid under pressure.
- the said engine may of course be used also as a pump for compressing an elastic fluid.
- the said engine comprises, essentially, between two parallel plates two spiral strips or hands having the shape of developed arcs of circles of the same pitch, the coils of which are engaged one in another and touch at a certain number of points, so as to form between the said bands and the said plates a certain number of separate chambers which become greater as the said points of contact are displaced from the starting-point of the said developed arcs of circles toward the ends of the same.
- Figures 1 to 13 are diagrams for the purpose of explaining the invention.
- Fig. 14rIS a vertical section of the engine on the line A A of Fig. 15.
- Fig. 15 is a sectional view on the line B B of Fig. 14.
- Fig. 16 is a sectional view on the line C C of Fig. 15.
- Fig. 17 is a detail of a joint.
- Figs. 18 and 19 are respectively a vertical section and a plan of a shifting device as to the direction of rotation.
- Figs. 20, 21, and 22 show modified forms of the engine.
- the developed arc of a circle is the curve described by the end a, Fig. l, of an inextensible wire which unrolls from a fixed circumference while still remaining stretched and without moving out of the plane of the circumference.
- a point 5 on the wire, Fig. 2 at a distance 0 from (0 describes a developed arc of a circle equal to the first one and of which each point is at a distance 0 from the first curve.
- two perpendicular lines a a and Z) 6 Fig. 3 drawn from a plane p are so moved as to describe curves, they give rise to two curved surfaces.
- the space comprised between the said curved surfaces and the planes p and p constitutes a spiral band.
- Such a band secured to a circular plate as seen in perspective in Fig. 4e constitutes one of the essential members of the engine.
- a similar band secured to the plate 19 constitutes the other member of the engine.
- each coil of the band 1 is tangent at two points to the corresponding coil of the band 2. If a movement of translation is imparted to the band 1 with respect to the band 2, in keeping the said bands in the same direction, one with respect to the other, so that the curved surfaces still remain tangent the one to the other, each point of the band 1 will describe a circumference.
- the steam will always operate at full pressure in the central chamber (Z and will expand at each revolution in the lateral chambers c c and will escape at f.
- the oblique'hatchings in Figs. 6 to 13 show the steam at full pressure.
- the vertical or horizontal hatchings show the steam when expanding, and the dotted hatchings show the steam escaping.
- one of the bands may be fixed, or circular movements of translation may be imparted to both the bands, or a general or other movement of rotation may be imparted to the two bands taken together independently of the relative circular movement of translation which takes place between the bands.
- 1 and 2 designate spiral bands which are integral with the plates 3 and a, respectively.
- a bent shaft 5 having two cranks 6 7 at one hundred and eighty degrees.
- the center of the plate 3 is mounted on the crank 6 by means of a stalling-box 8, and the center of plate 4 is mounted on the crank 7 by means of a stuffing-box 9.
- the plates carry extensions 1011, through which pass bent shafts 12, mounted in a frame 13. The latter is carried by the sleeves 14c 15, loosely mounted on the shaft 5 and which rest in the bearings 16 17 of the main frame, so as to revolve therein.
- the shafts 12 are provided with other cranks 22 23, directed at right angles to the cranks 19 20 and connected together by lateral links or rods 2 1 25.
- the shaft 5 is provided with a duct 27, the shaft terminating in a stuffing-box 28, which is connected to a suitable source of steam.
- the steam after flowing through the coils and escaping at f is exhausted into an annular chamber 29, connected by conducts 30 with an exhaustpipe 31, provided across the main frame.
- the said conducts 30, which terminate in the sleeve 15, must allow the plate 4 to move.
- they may be provided with either jointing or telescopic parts or, as shown in the drawings, with a nozzle 32, sliding against the plate 1 in the same manner as a drawer having a circular movement.
- the joints between the lateral edges of the bands 1 and 2 and the plates 1 and. 3 and between the lateral edges of the circular casings 29 may be rendered steam-tight by means of suitable 1I16 L1'1S--"SI1Cl1, for instance, as segments 33, inserted in grooves in the said edges and pressed by springs 3a. (See Fig. 17.)
- the saidsegments may be provided in their lateral faces with one or several stuflinggrooves 4:6.
- the joints between the curved surfaces of the bands are easily rendered steam-tight by polishing, the contacts between the same being comparatively wide.
- either the pulley 18 or the pulley 26 may be braked at will to render motionless the frame 13 or the shaft 5. 1n the former case the pulley 26 rotates in the direction of the arrow D, Fig. 14'; in the latter case the pulley 18 rotates in the direction of the arrow E.
- the transmission of power will be obtained by means of a belt which can be brought alternatively on the pulleys 18 and 26.
- the direction of rotation may also be changed by means of other suitable devicessuch, for instance, as that shown in Figs. 18 and 19.
- the sleeve 35 may be put-in connection either with the shaft 5 or with the socket 14 by means of a piece composed of a ring 36, sliding on the socket 1 1, and of two branch parts 37, sliding in the rectilinear grooves 38, provided on the inner side of the sleeve
- Each of the said branch parts carries a spur 39, sliding in the spiral grooves 40 and 4:5 of the shafts 5 and 14. 111 the position shown in Fig. 18 if the socket 1 1 rotates in the direction of the arrow F the sleeve 35 rotates in the same direction, the shaft 5 remaining motionless.
- the engine may be arranged as shown in Fig. 20'that is, the frame 13 may be secured to the main frame of the machine.
- the engine may also be so arranged that the axes shall be vertical, as shown in Fig.
- One of the plates-say plate 3together with the spiral band, will then be secured to the main frame 43, and the other plate 4 is movable on plate 3 and guided by the cranks 20.
- the bent shaft 5 is held in an upright position by a cross-bar 44, secured to the main frame.
- the construction may be modified in many ways. It may again be modified in combining two or more pairs of spiral bands.
- the engine comprises two pairs of spiral bands 1 2 and 1 2.
- the bands 1 and 1 are secured on the lateral plates 3 and 3, and the bands 2 and 2 are secured on the middle plate 4.
- the cranks 6 and 6, which carry the plates 1 and 1, are in front one of the other, and the crank 7, which carries the plate 4, is diametrically opposed to the same with respect to the axis of shaft 5.
- the plates are guided and the engine operates in the same manner as hereinbefore described with reference to Figs. 14 to 16.
- the rotation of the engine is obtained by the continuous admission of a motive fluid, and the expansion of the latter is as complete as may be desired, the motive effort is regular, the operation is soft and silent, and the engine can be started under a load.
- a rotary engine comprising two parallel plates two spiral bands located between the plates and engaged the one in the other and guiding means to cause one of the bands to make a circular movement of translation with respect to the other band.
- a rotary engine comprising two parallel plates, two spiral bands engaged the one in the other and integral with the two plates respectively, and guiding means to cause one of the bands or one of the plates to make a circular movement of translation with respect to the other band or the other plate.
- a rotary engine comprising two parallel plates two spiral bands between the said plates and engaged the one in the other, guiding means to cause one of the bands to make a circular movement of translation with respect to the other band, and a duct or conduit to conduct the incoming motive fluid under pressure to the center of the said spiral bands.
- a rotary engine comprising a bent shaft having two opposite cranks, two parallel plates loosely mounted on the said cranks a frame loosely mounted on the shaft, cranks to connect the plates with the frame in causing the same to make a circular movement of translation with respect to the said frame, spiral bands integral with the said plates and engaged the one in the other, and means to render motionless at will either the said shaft or the said frame.
Description
No. 801,182. PATENTED OCT. 3,1905. L. GRBUX.
ROTARY ENGINE.
APPLICATION FILED JUNE 26,1905.
' 6 SHEETS-SHEET 1 =llu PATENTED' 001. 3, 1905 L. OREUX.
ROTARY ENGINE.
APPLICATION FILED JUNE 26.1905.
6 SHEETSSHEIIT 2 C ill/Ill! I m/sw wfo t l @0211 U2 aux No, 801.182. PATENTED OCT. 3,1905.
L. CREUX.
ROTARY ENGINE.
6 SHEETS-SHEET 8.
swam/Com.
v WWMM 19022 62 666426 No. 801,182. PATENTBD OCT. 3,1905.
L. GRBUX. ROTARY ENGINE.
APPLICATION FILED JUNE 26. 1905.
6 SHBETS-SHEET 5.
PATENTED OCT. 3, 1905.
L. GREUX. ROTARY ENGINE;
6 SHEETS-SHBBT 6.
l v E m m "m 7 y w m/w -4 M 0/ a w; 2 5 0 m 4 u 2 J i J 2 6 m y W// T m I. 7 d j I vwawfo b e022 CTe/ua? QUUW4MA- UNITED STATES PATENT QFFIGE.
Specification of Letters Patent.
Patented Oct. 3, 1905.
Application filed June 26, 1905. Serial No. 267,091
To aZZ whmn it may concern.-
Be it known that I, LEON CREUX, engineer, a citizen of the Republic of France, residing at 54 Rue Taitbout, Paris, in the Republic of France, have invented certain new and useful Improvements in Rotary Engines, of which the following is a specification.
The present invention relates to a rotary engine designed to be operated by an elastic fluid under pressure. The said engine may of course be used also as a pump for compressing an elastic fluid. The said engine comprises, essentially, between two parallel plates two spiral strips or hands having the shape of developed arcs of circles of the same pitch, the coils of which are engaged one in another and touch at a certain number of points, so as to form between the said bands and the said plates a certain number of separate chambers which become greater as the said points of contact are displaced from the starting-point of the said developed arcs of circles toward the ends of the same. The said displacement of the points of contact, which involves a circular movement of translation of one of the spiral bands with respect to the other, is pro duced naturally by the expansion of the elastic fluid inclosed in the chambers, the said fluid being introduced at the center of the spirals and escaping at the periphery.
In the accompanying drawings, which show several embodiments of the present invention,
Figures 1 to 13 are diagrams for the purpose of explaining the invention. Fig. 14rIS a vertical section of the engine on the line A A of Fig. 15. Fig. 15 is a sectional view on the line B B of Fig. 14. Fig. 16 is a sectional view on the line C C of Fig. 15. Fig. 17 is a detail of a joint. Figs. 18 and 19 are respectively a vertical section and a plan of a shifting device as to the direction of rotation. Figs. 20, 21, and 22 show modified forms of the engine.
The developed arc of a circle is the curve described by the end a, Fig. l, of an inextensible wire which unrolls from a fixed circumference while still remaining stretched and without moving out of the plane of the circumference. A point 5 on the wire, Fig. 2, at a distance 0 from (0 describes a developed arc of a circle equal to the first one and of which each point is at a distance 0 from the first curve. If two perpendicular lines a a and Z) 6 Fig. 3, drawn from a plane p are so moved as to describe curves, they give rise to two curved surfaces. The space comprised between the said curved surfaces and the planes p and p constitutes a spiral band. Such a band secured to a circular plate as seen in perspective in Fig. 4e, constitutes one of the essential members of the engine. A similar band secured to the plate 19 constitutes the other member of the engine.
If the two spiral bands 1 and 2 are engaged one within the other, as shown in Fig. 5, each coil of the band 1 is tangent at two points to the corresponding coil of the band 2. If a movement of translation is imparted to the band 1 with respect to the band 2, in keeping the said bands in the same direction, one with respect to the other, so that the curved surfaces still remain tangent the one to the other, each point of the band 1 will describe a circumference.
The spaces (Z c 0 &c., are entirely inclosed, and if the circular movement of translation takes place in the direction shown by the arrow the said spaces increase in size during the operation.
If steam is introduced at (Z and if the bands 1 and 2 are caused to move as just described, the expansive power of the steam will produce the relative movement of the bands in the direction shown by the arrow. The steam will occupy successively the spaces shaded in Figs. 6 to 13. Figs. 6 to 9 show the several phases during the first revolution. Figs. 10 to 13 show those of the second revolution.
The steam will always operate at full pressure in the central chamber (Z and will expand at each revolution in the lateral chambers c c and will escape at f. The oblique'hatchings in Figs. 6 to 13 show the steam at full pressure. The vertical or horizontal hatchings show the steam when expanding, and the dotted hatchings show the steam escaping.
To cause the spiral bands to move suitably one with respect to the other, all that need be done, as will be understood, is to connect the same by a suitable number of equal and parallel cranks or other similar connecting devices. According to the manner in which the bands or their connecting members are connected with the main frame of the engine, one of the bands may be fixed, or circular movements of translation may be imparted to both the bands, or a general or other movement of rotation may be imparted to the two bands taken together independently of the relative circular movement of translation which takes place between the bands.
I will lirst describe a steam-engine in which there may be secured to the main frame now a point of the bands themselves and then a point of their connecting members, so that a change in the direction of rotation may be obtained.
1 and 2 designate spiral bands which are integral with the plates 3 and a, respectively. Through the plates passes a bent shaft 5, having two cranks 6 7 at one hundred and eighty degrees. The center of the plate 3 is mounted on the crank 6 by means of a stalling-box 8, and the center of plate 4 is mounted on the crank 7 by means of a stuffing-box 9. On the other hand, the plates carry extensions 1011, through which pass bent shafts 12, mounted in a frame 13. The latter is carried by the sleeves 14c 15, loosely mounted on the shaft 5 and which rest in the bearings 16 17 of the main frame, so as to revolve therein. If the frame is rendered motionlesssay by the application of a brake on the pulley 18, carried by the sleeve l i the axes of the shafts 12 are fixed, so that the cranks 19 20 of the said shafts, connected, respectively, with the plates 3 4, only allow each of the latter to make a circular movement of translation the radius of which is equal to the radius of the cranks 6 and 7. In order that the guiding of the plates may not be interfered with by the passage at the dead-points, the shafts 12 are provided with other cranks 22 23, directed at right angles to the cranks 19 20 and connected together by lateral links or rods 2 1 25. If, on the other hand, by braking the pulley 26 of the shaft 5 the latter is rendered motionless, together with the cranks 6 and 7, and if at the same time the pulley 18 is set free, the plates 3 1 and the frame 13 are still capable of rotating, and during this general movement of rotation the relative circular movement of translation of the two plates and bands will still take place.
To allow of steam being introduced into the central chamber of the engine, the shaft 5 is provided with a duct 27, the shaft terminating in a stuffing-box 28, which is connected to a suitable source of steam. The steam after flowing through the coils and escaping at f is exhausted into an annular chamber 29, connected by conducts 30 with an exhaustpipe 31, provided across the main frame. The said conducts 30, which terminate in the sleeve 15, must allow the plate 4 to move. For that purpose they may be provided with either jointing or telescopic parts or, as shown in the drawings, with a nozzle 32, sliding against the plate 1 in the same manner as a drawer having a circular movement.
The joints between the lateral edges of the bands 1 and 2 and the plates 1 and. 3 and between the lateral edges of the circular casings 29 may be rendered steam-tight by means of suitable 1I16 L1'1S--"SI1Cl1, for instance, as segments 33, inserted in grooves in the said edges and pressed by springs 3a. (See Fig. 17.) The saidsegments may be provided in their lateral faces with one or several stuflinggrooves 4:6. The joints between the curved surfaces of the bands are easily rendered steam-tight by polishing, the contacts between the same being comparatively wide.
As mentioned above, either the pulley 18 or the pulley 26 may be braked at will to render motionless the frame 13 or the shaft 5. 1n the former case the pulley 26 rotates in the direction of the arrow D, Fig. 14'; in the latter case the pulley 18 rotates in the direction of the arrow E. The transmission of power will be obtained by means of a belt which can be brought alternatively on the pulleys 18 and 26. The direction of rotation may also be changed by means of other suitable devicessuch, for instance, as that shown in Figs. 18 and 19. The sleeve 35 may be put-in connection either with the shaft 5 or with the socket 14 by means of a piece composed of a ring 36, sliding on the socket 1 1, and of two branch parts 37, sliding in the rectilinear grooves 38, provided on the inner side of the sleeve Each of the said branch parts carries a spur 39, sliding in the spiral grooves 40 and 4:5 of the shafts 5 and 14. 111 the position shown in Fig. 18 if the socket 1 1 rotates in the direction of the arrow F the sleeve 35 rotates in the same direction, the shaft 5 remaining motionless.
To change the direction of rotation of the engine, the incoming steam is shut off and the piece 36 is moved forward in the direction of the arrow G. The spurs 39, sliding in the rectilinear grooves 415 and then coming in contact with the shaft 5, become engaged in the spiral grooves 40, which terminate in a rectilinear part ll. A shock is thus avoided which the system of mechanism would not be capable of resisting, and the shaft 5 takes gradually the same speed as the sleeve 35. Then all that need be done is-to render the socket 14 motionless and to turn the steam slowly on again. To change the rotation in the opposite direction, a shifting piece 42 will cause the spur 39 to follow the rectilinear groove 38 by closing the entrance of the spiral groove 40. When the spur will be in contact with the socket 14, it will become engaged in the spiral groove 40 and will then operate in the same manner as previously.
In case the change in the direction of rotation is not necessary the engine may be arranged as shown in Fig. 20'that is, the frame 13 may be secured to the main frame of the machine.
The engine may also be so arranged that the axes shall be vertical, as shown in Fig.
21. One of the plates-say plate 3together with the spiral band, will then be secured to the main frame 43, and the other plate 4 is movable on plate 3 and guided by the cranks 20. The bent shaft 5 is held in an upright position by a cross-bar 44, secured to the main frame.
As will be understood, the construction may be modified in many ways. It may again be modified in combining two or more pairs of spiral bands. For instance, in Fig. 22 the engine comprises two pairs of spiral bands 1 2 and 1 2. The bands 1 and 1 are secured on the lateral plates 3 and 3, and the bands 2 and 2 are secured on the middle plate 4. The cranks 6 and 6, which carry the plates 1 and 1, are in front one of the other, and the crank 7, which carries the plate 4, is diametrically opposed to the same with respect to the axis of shaft 5. The plates are guided and the engine operates in the same manner as hereinbefore described with reference to Figs. 14 to 16.
In all the embodiments of the present invention, as herein shown and described, the rotation of the engine is obtained by the continuous admission of a motive fluid, and the expansion of the latter is as complete as may be desired, the motive effort is regular, the operation is soft and silent, and the engine can be started under a load.
I claim 1. A rotary engine comprising two parallel plates two spiral bands located between the plates and engaged the one in the other and guiding means to cause one of the bands to make a circular movement of translation with respect to the other band.
2. A rotary engine comprising two parallel plates, two spiral bands engaged the one in the other and integral with the two plates respectively, and guiding means to cause one of the bands or one of the plates to make a circular movement of translation with respect to the other band or the other plate.
3. A rotary engine comprising two parallel plates two spiral bands between the said plates and engaged the one in the other, guiding means to cause one of the bands to make a circular movement of translation with respect to the other band, and a duct or conduit to conduct the incoming motive fluid under pressure to the center of the said spiral bands.
4. A rotary engine comprising a bent shaft having two opposite cranks, two parallel plates loosely mounted on the said cranks a frame loosely mounted on the shaft, cranks to connect the plates with the frame in causing the same to make a circular movement of translation with respect to the said frame, spiral bands integral with the said plates and engaged the one in the other, and means to render motionless at will either the said shaft or the said frame.
In testimony that I claim the foregoing as my invention I have signed my name in presence of two subscribing witnesses.
LEON CREUX.
Witnesses:
HANSON 0. (10x12, MAURICE Roux.
Priority Applications (1)
Application Number | Priority Date | Filing Date | Title |
US26709105A US801182A (en) | 1905-06-26 | 1905-06-26 | Rotary engine. |
Applications Claiming Priority (1)
Publications (1)
Publication Number | Publication Date |
US801182A true US801182A (en) | 1905-10-03 |
Family
ID=2869668
Family Applications (1)
Application Number | Title | Priority Date | Filing Date |
US26709105A Expired - Lifetime US801182A (en) | 1905-06-26 | 1905-06-26 | Rotary engine. |
Country Status (1)
Country | Link |
US (1) | US801182A (en) |
Cited By (103)
Publication number | Priority date | Publication date | Assignee | Title |
US2475247A (en) * | 1944-05-22 | 1949-07-05 | Mikulasek John | Planetary piston fluid displacement mechanism |
US2494100A (en) * | 1944-03-27 | 1950-01-10 | Mikulasek John | Displacement mechanism |
US2809779A (en) * | 1956-02-23 | 1957-10-15 | William L W Girvin | Rotary compressor or motor |
US2841089A (en) * | 1953-05-29 | 1958-07-01 | Rand Dev Corp | Scroll pump |
US3011694A (en) * | 1958-09-12 | 1961-12-05 | Alsacienne Constr Meca | Encapsuling device for expanders, compressors or the like |
US3062022A (en) * | 1959-12-15 | 1962-11-06 | John R Averill | Heat pump |
DE2603462A1 (en) * | 1975-02-07 | 1976-08-19 | Aginfor Ag | DISPLACEMENT MACHINE FOR COMPRESSIBLE MEDIA |
DE2612344A1 (en) * | 1975-03-24 | 1976-10-07 | Little Inc A | SEAL FOR A DISPLACEMENT MACHINE |
DE2617290A1 (en) * | 1975-04-21 | 1976-11-04 | Little Inc A | SCREW ELEMENT FOR A DEVICE WITH COMPLEMENTARY SCREW ELEMENTS |
US4192152A (en) * | 1978-04-14 | 1980-03-11 | Arthur D. Little, Inc. | Scroll-type fluid displacement apparatus with peripheral drive |
US4199308A (en) * | 1978-10-02 | 1980-04-22 | Arthur D. Little, Inc. | Axial compliance/sealing means for improved radial sealing for scroll apparatus and scroll apparatus incorporating the same |
US4303379A (en) * | 1978-09-09 | 1981-12-01 | Sankyo Electric Company Limited | Scroll-type compressor with reduced housing radius |
US4304535A (en) * | 1978-10-12 | 1981-12-08 | Sankyo Electric Company Limited | Scroll-type compressor units with minimum housing and scroll plate radii |
WO1982002739A1 (en) * | 1981-02-12 | 1982-08-19 | Little Inc A | Mechanically actuated tip seals for scroll apparatus and scroll apparatus embodying the same |
EP0065426A2 (en) * | 1981-05-20 | 1982-11-24 | Sanden Corporation | Scroll manufacturing tool |
EP0066426A2 (en) * | 1981-05-20 | 1982-12-08 | Sanden Corporation | Scroll manufacturing tool |
US4411605A (en) * | 1981-10-29 | 1983-10-25 | The Trane Company | Involute and laminated tip seal of labyrinth type for use in a scroll machine |
US4456051A (en) * | 1981-03-02 | 1984-06-26 | Sanden Corporation | Scroll manufacturing method |
US4464100A (en) * | 1981-06-24 | 1984-08-07 | Hitachi, Ltd. | Scroll fluid apparatus handling compressible fluid |
US4477239A (en) * | 1982-10-12 | 1984-10-16 | Sanden Corporation | Scroll type fluid displacement apparatus with offset wraps for reduced housing diameter |
US4487248A (en) * | 1982-07-23 | 1984-12-11 | Sanden Corporation | Scroll manufacturing method and tool |
US4527963A (en) * | 1982-09-30 | 1985-07-09 | Sanden Corporation | Scroll type compressor with lubricating system |
US4545746A (en) * | 1983-03-15 | 1985-10-08 | Sanden Corporation | Rotation-preventing device for an orbiting piston-type fluid displacement |
US4547138A (en) * | 1983-03-15 | 1985-10-15 | Sanden Corporation | Lubricating mechanism for scroll-type fluid displacement apparatus |
US4551081A (en) * | 1981-10-12 | 1985-11-05 | Sanden Corporation | Pulley mechanism for fluid displacement apparatus |
US4561832A (en) * | 1983-03-14 | 1985-12-31 | Sanden Corporation | Lubricating mechanism for a scroll-type fluid displacement apparatus |
US4575319A (en) * | 1984-08-01 | 1986-03-11 | Sanden Corporation | Method and apparatus for adjusting the angular relationship of spiral elements in a scroll type fluid displacement apparatus |
US4575318A (en) * | 1984-08-16 | 1986-03-11 | Sundstrand Corporation | Unloading of scroll compressors |
US4589828A (en) * | 1982-08-07 | 1986-05-20 | Sanden Corporation | Rotation preventing device for an orbiting member of a fluid displacement apparatus |
US4627799A (en) * | 1984-08-27 | 1986-12-09 | Sanden Corporation | Axial sealing mechanism for a scroll type fluid displacement apparatus |
US4627800A (en) * | 1983-11-04 | 1986-12-09 | Sanden Corporation | Scroll type fluid displacement compressor with spiral wrap elements of varying thickness |
US4645435A (en) * | 1983-11-19 | 1987-02-24 | Sanden Corporation | Rotation preventing device for an orbiting member of a fluid displacement apparatus |
US4645436A (en) * | 1984-11-19 | 1987-02-24 | Sanden Corporation | Scroll type fluid displacement apparatus with improved anti-wear device |
US4655697A (en) * | 1984-05-18 | 1987-04-07 | Mitsubishi Denki Kabushiki Kaisha | Scroll-type apparatus with gap adjustment means |
US4677949A (en) * | 1985-08-19 | 1987-07-07 | Youtie Robert K | Scroll type fluid displacement apparatus |
US4740143A (en) * | 1985-05-16 | 1988-04-26 | Mitsubishi Denki Kabushiki Kaisha | Scroll-type fluid transferring machine with gap adjustment between scroll members |
US4795324A (en) * | 1985-11-27 | 1989-01-03 | Mitsubishi Denki Kabushiki Kaisha | Scroll-type fluid transferring machine with deformable thrust bearing |
US4824346A (en) * | 1980-03-18 | 1989-04-25 | Sanden Corporation | Scroll type fluid displacement apparatus with balanced drive means |
US4890987A (en) * | 1987-03-20 | 1990-01-02 | Sanden Corporation | Scroll type compressor with seal supporting anti-wear plate portions |
US4900238A (en) * | 1987-03-20 | 1990-02-13 | Sanden Corporation | Scroll type compressor with releasably secured hermetic housing |
US4927339A (en) * | 1988-10-14 | 1990-05-22 | American Standard Inc. | Rotating scroll apparatus with axially biased scroll members |
US4940396A (en) * | 1988-01-14 | 1990-07-10 | Sanden Corporation | Hermatic scroll type compressor with two casings and center blocks |
US4956058A (en) * | 1983-03-15 | 1990-09-11 | Sanden Corporation | Scroll type fluid displacement apparatus with surface treated spiral element |
US5094205A (en) * | 1989-10-30 | 1992-03-10 | Billheimer James C | Scroll-type engine |
US5154591A (en) * | 1990-06-20 | 1992-10-13 | Aginfor Ag Fur Industrielle Forschung | Displacement machine employing a plurality of intermeshing spiral displacement bodies |
US5165878A (en) * | 1989-02-10 | 1992-11-24 | Nippon Soken, Inc | Scroll type compressor with slide guide for preventing rotation of the moveable scroll |
US5178526A (en) * | 1991-12-17 | 1993-01-12 | Carrier Corporation | Coupling mechanism for co-orbiting scroll members |
US5203307A (en) * | 1989-06-29 | 1993-04-20 | Burtis Wilson A | Rotary wankel type engine |
US5295808A (en) * | 1991-03-29 | 1994-03-22 | Hitachi, Ltd. | Synchronous rotating type scroll fluid machine |
US5449279A (en) * | 1993-09-22 | 1995-09-12 | American Standard Inc. | Pressure biased co-rotational scroll apparatus with enhanced lubrication |
US5458471A (en) * | 1992-08-14 | 1995-10-17 | Ni; Shimao | Scroll-type fluid displacement device having high built-in volume ratio and semi-compliant biasing mechanism |
US5591022A (en) * | 1995-10-18 | 1997-01-07 | General Motors Corporation | Scroll compressor with integral anti rotation means |
US5616015A (en) * | 1995-06-07 | 1997-04-01 | Varian Associates, Inc. | High displacement rate, scroll-type, fluid handling apparatus |
EP0769623A1 (en) | 1995-10-20 | 1997-04-23 | Sanden Corporation | Scroll type fluid displacement apparatus with an axial seal plate |
WO1998037327A1 (en) | 1997-02-25 | 1998-08-27 | Varian Associates, Inc. | Two stage vacuum pumping apparatus |
US5836752A (en) * | 1996-10-18 | 1998-11-17 | Sanden International (U.S.A.), Inc. | Scroll-type compressor with spirals of varying pitch |
US5899676A (en) * | 1996-03-18 | 1999-05-04 | Sanden Corporation | Oldham coupling mechanism for a scroll type fluid displacement apparatus |
US5927958A (en) * | 1996-03-14 | 1999-07-27 | Kabushiki Kaisha Toshiba | Fluid machinery having a sealing member between stepped spirals |
WO1999042728A1 (en) | 1998-02-19 | 1999-08-26 | Varian, Inc. | Improved tip seal for scroll-type vacuum pump |
WO2000006906A1 (en) | 1998-07-30 | 2000-02-10 | Varian, Inc. | Scroll-type vacuum pump |
US6059540A (en) * | 1997-09-22 | 2000-05-09 | Mind Tech Corp. | Lubrication means for a scroll-type fluid displacement apparatus |
US6071101A (en) * | 1997-09-22 | 2000-06-06 | Mind Tech Corp. | Scroll-type fluid displacement device having flow diverter, multiple tip seal and semi-radial compliant mechanism |
US6099279A (en) * | 1996-09-20 | 2000-08-08 | Hitachi, Ltd. | Displacement fluid machine |
US6126422A (en) * | 1997-10-24 | 2000-10-03 | American Standard Inc. | Tip seal for scroll type compressor and manufacturing method therefor |
US6190148B1 (en) * | 1995-11-17 | 2001-02-20 | Mindtech Corporation | Scroll-type fluid displacement device having sliding surface thrust bearing |
US6193487B1 (en) | 1998-10-13 | 2001-02-27 | Mind Tech Corporation | Scroll-type fluid displacement device for vacuum pump application |
WO2001075273A2 (en) | 2000-03-31 | 2001-10-11 | Battelle Memorial Institute | Scroll compressor |
US6439864B1 (en) * | 1999-01-11 | 2002-08-27 | Air Squared, Inc. | Two stage scroll vacuum pump with improved pressure ratio and performance |
DE10225774C1 (en) * | 2002-06-10 | 2003-12-11 | Vacuubrand Gmbh & Co Kg | Vacuum pump, for condensing and aggressive gases, is a dry pump with a membrane pump stage and a spiral scroll pump stage |
US20040219047A1 (en) * | 2002-11-04 | 2004-11-04 | Enjiu Ke | Scroll type fluid machinery |
DE102005042451A1 (en) * | 2005-09-06 | 2007-03-15 | Vacuubrand Gmbh + Co Kg | Vacuum pumping device for use as oil-lubricated rotary vane pump, has drive and rotary units arranged such that transient area has sealing units separating conveying area from drive area, where one of sealing units is ferrous fluid seal |
US20090022613A1 (en) * | 2007-07-16 | 2009-01-22 | Dai Zhihuang | Asynchronous non-constant-pitch spiral scroll-type fluid displacement machine |
US20090028724A1 (en) * | 2007-07-27 | 2009-01-29 | Zili Sun | Self-modulated scroll compressor with optimized built-in volume ratio |
DE102007043324A1 (en) | 2007-09-12 | 2009-03-19 | Fischer, Francesco Peter, Dipl.-Ing. | Method for pumping medium e.g. liquid medium, according to orbital displacer principle, to transport medium, involves providing orbital coil close to housing of coil for separating pressure side from inlet side continuously |
US20090148327A1 (en) * | 2007-12-07 | 2009-06-11 | Preston Henry Carter | Rotary postive displacement combustor engine |
EP2133511A1 (en) | 2008-06-10 | 2009-12-16 | Energeticamente Rinnovabili SRL | Internal combustion scroll engine |
US20100058755A1 (en) * | 2008-09-08 | 2010-03-11 | L5A, Llc | Closed loop scroll expander engine |
EP2204531A1 (en) | 2007-10-17 | 2010-07-07 | Eneftech Innovation SA | Scroll device for compression or expansion |
US20100175946A1 (en) * | 2009-01-13 | 2010-07-15 | Honda Motor Co., Ltd. | Supercharger-equipped internal combustion engine for saddle-ride type vehicle |
US20100284846A1 (en) * | 2007-11-08 | 2010-11-11 | Enjiu Ke | Scroll Type Fluid Machinery |
EP2306024A2 (en) | 2009-09-25 | 2011-04-06 | Agilent Technologies, Inc. | Scroll pump with isolation barrier |
US20130302199A1 (en) * | 2012-04-25 | 2013-11-14 | Anest Iwata Corporation | Scroll expander |
US20130309116A1 (en) * | 2012-04-25 | 2013-11-21 | Anest Iwata Corporation | Double rotation type scroll expander and power generation apparatus including same |
WO2014019041A1 (en) | 2012-08-03 | 2014-02-06 | Whirlpool S.A. | Fluid compressor based on scroll type mechanism |
WO2014040153A1 (en) | 2012-09-06 | 2014-03-20 | Whirpool S.A. | Hydrodynamic bearing applied on a contact interface of a fluid compressor based on a spiral type mechanism |
WO2014111318A2 (en) | 2013-01-18 | 2014-07-24 | Mahle International Gmbh | Spiral compressor |
DE102013200805A1 (en) | 2013-01-18 | 2014-07-24 | Mahle International Gmbh | Scroll compressor installed in air conditioning apparatus for delivering fluid, provides orbiting motion of inner ring with respect to outer ring during activation state so that slider mechanism compress compressor for delivering fluid |
DE102013200808A1 (en) | 2013-01-18 | 2014-07-24 | Mahle International Gmbh | Spiral compressor or expansion machine for compressing fluid, has electric motor is integrated in oscillating slide mechanism for providing orbiting motion of inner ring relative to outer ring in activated state |
WO2016161488A2 (en) | 2015-04-09 | 2016-10-13 | Atlas Copco Airpower, Naamloze Vennootschap | Scroll type apparatus and method for manufacturing such a scroll type apparatus and seal for such a scroll type apparatus |
DE102018109852A1 (en) | 2018-04-24 | 2019-10-24 | Joma-Polytec Gmbh | scroll pump |
US10508543B2 (en) | 2015-05-07 | 2019-12-17 | Air Squared, Inc. | Scroll device having a pressure plate |
US10519815B2 (en) | 2011-08-09 | 2019-12-31 | Air Squared, Inc. | Compact energy cycle construction utilizing some combination of a scroll type expander, pump, and compressor for operating according to a rankine, an organic rankine, heat pump or combined organic rankine and heat pump cycle |
US10683865B2 (en) | 2006-02-14 | 2020-06-16 | Air Squared, Inc. | Scroll type device incorporating spinning or co-rotating scrolls |
US10865793B2 (en) | 2016-12-06 | 2020-12-15 | Air Squared, Inc. | Scroll type device having liquid cooling through idler shafts |
US11047389B2 (en) | 2010-04-16 | 2021-06-29 | Air Squared, Inc. | Multi-stage scroll vacuum pumps and related scroll devices |
US11067080B2 (en) | 2018-07-17 | 2021-07-20 | Air Squared, Inc. | Low cost scroll compressor or vacuum pump |
CN114893398A (en) * | 2022-05-20 | 2022-08-12 | 重庆超力高科技股份有限公司 | Scroll compressor and method of overcoming overturning moment |
US11454241B2 (en) | 2018-05-04 | 2022-09-27 | Air Squared, Inc. | Liquid cooling of fixed and orbiting scroll compressor, expander or vacuum pump |
US11473572B2 (en) | 2019-06-25 | 2022-10-18 | Air Squared, Inc. | Aftercooler for cooling compressed working fluid |
US11530703B2 (en) | 2018-07-18 | 2022-12-20 | Air Squared, Inc. | Orbiting scroll device lubrication |
US11885328B2 (en) | 2021-07-19 | 2024-01-30 | Air Squared, Inc. | Scroll device with an integrated cooling loop |
US11898557B2 (en) | 2020-11-30 | 2024-02-13 | Air Squared, Inc. | Liquid cooling of a scroll type compressor with liquid supply through the crankshaft |
US11933299B2 (en) | 2018-07-17 | 2024-03-19 | Air Squared, Inc. | Dual drive co-rotating spinning scroll compressor or expander |
1905
- 1905-06-26 US US26709105A patent/US801182A/en not_active Expired - Lifetime
Cited By (139)
US3989422A (en) * | 1975-02-07 | 1976-11-02 | Aginfor Ag Fur Industrielle Forschung | Displacement machine for compressible media |
US3994636A (en) * | 1975-03-24 | 1976-11-30 | Arthur D. Little, Inc. | Axial compliance means with radial sealing for scroll-type apparatus |
JPS6276201U (en) * | 1975-03-24 | 1987-05-15 | ||
JPH0143514Y2 (en) * | 1975-03-24 | 1989-12-18 | ||
US3994635A (en) * | 1975-04-21 | 1976-11-30 | Arthur D. Little, Inc. | Scroll member and scroll-type apparatus incorporating the same |
JPH01211602A (en) * | 1975-04-21 | 1989-08-24 | Arthur D Little Inc | Positive displacement type fluid device |
US4572276A (en) * | 1981-03-02 | 1986-02-25 | Sanden Corporation | Scroll manufacturing tool |
EP0066426A3 (en) * | 1981-05-20 | 1983-08-24 | Sanden Corporation | Scroll manufacturing tool |
EP0065426A3 (en) * | 1981-05-20 | 1983-08-17 | Sanden Corporation | Scroll manufacturing tool |
US4730375A (en) * | 1984-05-18 | 1988-03-15 | Mitsubishi Denki Kabushiki Kaisha | Method for the assembly of a scroll-type apparatus |
US4824343A (en) * | 1985-05-16 | 1989-04-25 | Mitsubishi Denki Kabushiki Kaisha | Scroll-type fluid transferring machine with gap adjustment between scroll members |
US6217303B1 (en) | 1996-09-20 | 2001-04-17 | Hitachi, Ltd. | Displacement fluid machine |
US6220840B1 (en) | 1996-10-18 | 2001-04-24 | Sanden International (U.S.A.), Inc. | Wall shape for scroll-type compressor vanes |
US6270713B1 (en) * | 1997-10-24 | 2001-08-07 | American Standard International Inc. | Tip seal for scroll type compressors and manufacturing method therefor |
US6068459A (en) * | 1998-02-19 | 2000-05-30 | Varian, Inc. | Tip seal for scroll-type vacuum pump |
EP1129294A4 (en) * | 1998-10-13 | 2004-07-14 | Mind Tech Corp | Scroll-type fluid displacement device for vacuum pump application |
EP1129294A1 (en) * | 1998-10-13 | 2001-09-05 | Mind Tech Corp. | Scroll-type fluid displacement device for vacuum pump application |
DE10393645B4 (en) * | 2002-11-04 | 2009-10-08 | Ke, Enjiu, Windsor | Turbomachine coupled with multiple spiral members through a plurality of rotation-resistant elements |
US6988876B2 (en) | 2002-11-04 | 2006-01-24 | Enjiu Ke | Scroll type fluid machinery |
DE102005042451B4 (en) * | 2005-09-06 | 2007-07-26 | Vacuubrand Gmbh + Co Kg | Vacuum pump device |
US7938634B2 (en) * | 2007-07-27 | 2011-05-10 | Scroll Technologies | Self-modulated scroll compressor with optimized built-in volume ratio |
DE202007019039U1 (en) | 2007-09-12 | 2010-06-24 | Fischer, Francesco Peter, Dipl.-Ing. | Device for pumping a medium according to the Orbitalverdrängerprinzip |
US20100254835A1 (en) * | 2007-10-17 | 2010-10-07 | Malick Kane | Scroll device integrating a feed pump |
US8764421B2 (en) | 2007-11-08 | 2014-07-01 | Shanghai Universoon AutoParts Co. | Scroll type fluid machinery |
US7958862B2 (en) * | 2007-12-07 | 2011-06-14 | Secco2 Engines, Inc. | Rotary positive displacement combustor engine |
US8479516B2 (en) | 2008-09-08 | 2013-07-09 | SECCO2 Engines Inc. | Closed loop scroll expander |
US8006496B2 (en) | 2008-09-08 | 2011-08-30 | Secco2 Engines, Inc. | Closed loop scroll expander engine |
US8668040B2 (en) * | 2009-01-13 | 2014-03-11 | Honda Motor Co., Ltd. | Supercharger-equipped internal combustion engine for saddle-ride type vehicle |
US10774690B2 (en) | 2011-08-09 | 2020-09-15 | Air Squared, Inc. | Compact energy cycle construction utilizing some combination of a scroll type expander, pump, and compressor for operating according to a rankine, an organic rankine, heat pump, or combined organic rankine and heat pump cycle |
US9175683B2 (en) * | 2012-04-25 | 2015-11-03 | Anest Iwata Corporation | Double rotation type scroll expander and power generation apparatus including same |
US9316224B2 (en) * | 2012-04-25 | 2016-04-19 | Anest Iwata Corporation | Scroll expander |
US9593682B2 (en) | 2012-09-06 | 2017-03-14 | Whirlpool S.A. | Hydrodynamic bearing applied on a contact interface of a fluid compressor based on a spiral type mechanism |
US9771937B2 (en) | 2013-01-18 | 2017-09-26 | Mahle International Gmbh | Spiral compressor |
DE102013200807A1 (en) | 2013-01-18 | 2014-07-24 | Mahle International Gmbh | scroll compressor |
US11692550B2 (en) | 2016-12-06 | 2023-07-04 | Air Squared, Inc. | Scroll type device having liquid cooling through idler shafts |
CN114893398B (en) * | 2022-05-20 | 2023-08-15 | 重庆超力高科技股份有限公司 | Scroll compressor and method for overcoming overturning moment |
Similar Documents
Publication | Publication Date | Title |
US801182A (en) | Rotary engine. | |
US1378065A (en) | Rotary engine or pump | |
US3277832A (en) | Rotary apparatus with movable elements enabling a fluid or fluidized solid to be compressed expanded or driven | |
US1101329A (en) | Pump or motor. | |
US899040A (en) | Rotary engine. | |
US309734A (en) | oehlmann | |
US551669A (en) | fellows | |
US959856A (en) | Rotary-engine. | |
US752784A (en) | Rotary engine | |
US711168A (en) | Rotary engine. | |
US979323A (en) | Prime mover. | |
US845973A (en) | Rotary engine. | |
US785408A (en) | Rotary engine. | |
US713663A (en) | Rotary engine. | |
US1017850A (en) | Rotary motor. | |
US277648A (en) | Rocking piston-engine | |
US1042634A (en) | Valve mechanism for motors. | |
US642104A (en) | Rotary engine. | |
US1076865A (en) | Reversible steam-turbine. | |
US1047518A (en) | Rotary motor. | |
US789760A (en) | Turbine. | |
US1035253A (en) | Rotary engine. | |
US303781A (en) | Rotary steam-motor | |
US709323A (en) | Rotary steam-engine. | |
US748689A (en) | Rotary motor |
