Engineering ToolBox - Resources, Tools and Basic Information for Engineering and Design of Technical Applications!
AWG - American Wire Gauge Converting Chart
American Wire Gauge (AWG) vs. cross sectional area converter.
AWG - American Wire Gauge - is an U.S. standard for wire conductor size. The "gauge" is related to the diameter of the wire.
  • larger "gauge" -> smaller diameter and thinner wire
awg wire gauge
The AWG standard includes copper, aluminum and other wire materials. Typical household copper wiring is AWG number 12 or 14. Telephone wire is usually 22, 24, or 26. The higher the gauge number, the smaller the diameter and the thinner the wire.
The table below can be used to convert American Wire Gauge (AWG) to square mm cross sectional area.
AWG - American Wire Gauges - Diameters and Areas
American Wire Gauge
(#AWG)
Diameter
(inches)
Diameter
(mm)
Cross Sectional Area
(mm2)
0000 (4/0) 0.460 11.7 107
000 (3/0) 0.410 10.4 85.0
00 (2/0) 0.365 9.27 67.4
0 (1/0) 0.325 8.25 53.5
1 0.289 7.35 42.4
2 0.258 6.54 33.6
3 0.229 5.83 26.7
4 0.204 5.19 21.1
5 0.182 4.62 16.8
6 0.162 4.11 13.3
7 0.144 3.67 10.6
8 0.129 3.26 8.36
9 0.114 2.91 6.63
10 0.102 2.59 5.26
11 0.0907 2.30 4.17
12 0.0808 2.05 3.31
13 0.0720 1.83 2.63
14 0.0641 1.63 2.08
15 0.0571 1.45 1.65
16 0.0508 1.29 1.31
17 0.0453 1.15 1.04
18 0.0403 1.02 0.82
19 0.0359 0.91 0.65
20 0.0320 0.81 0.52
21 0.0285 0.72 0.41
22 0.0254 0.65 0.33
23 0.0226 0.57 0.26
24 0.0201 0.51 0.20
25 0.0179 0.45 0.16
26 0.0159 0.40 0.13
Note! - the diameter of a solid and stranded wire with the same AWG is not identical. The diameter of a stranded wire is larger than the diameter of a solid wire.
American Wire Gauge - AWG, Imperial and Metric Units
Download and print AWG chart
Related Topics
  • Electrical
    Electrical engineering with units, amps and electrical wiring. Wire gauges, electrical formulas, motors and more.
Related Documents
Search
Search is the most efficient way to navigate the Engineering ToolBox.
Engineering ToolBox - SketchUp Extension - Online 3D modeling!
3D Engineering ToolBox Extension to SketchUp - add parametric components to your SketchUp model
Add standard and customized parametric components - like flange beams, lumbers, piping, stairs and more - to your Sketchup model with the Engineering ToolBox - SketchUp Extension - enabled for use with older versions of the amazing SketchUp Make and the newer "up to date" SketchUp Pro . Add the Engineering ToolBox extension to your SketchUp Make/Pro from the Extension Warehouse !
Translate this Page
Translate this page to Your Own Language .
About the Engineering ToolBox!
Privacy Policy
We don't collect information from our users. More about
We use a third-party to provide monetization technologies for our site. You can review their privacy and cookie policy here.
You can change your privacy settings by clicking the following button: .
Citation
This page can be cited as
  • The Engineering ToolBox (2004). AWG - American Wire Gauge Converting Chart. [online] Available at: https://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html [Accessed Day Month Year].
Modify the access date according your visit.
3D Engineering ToolBox - draw and model technical applications! 2D Engineering ToolBox - create and share online diagram drawing templates! Engineering ToolBox Apps - mobile online and offline engineering applications!
Unit Converter
4.10.13
