Eolien : pour ou contre les éoliennes ?
moinsdewatt
x 554
Re: Eolien : pour ou contre les éoliennes ?
par moinsdewatt » 06/11/16, 14:30
Un nouveau concept de stockage d'énergie pour l' éolien.
Couplage de ce que j' appellerai du micro-STEP avec un parc de 4 éoliennes.
Ça va se faire en Allemagne, avec General Electric comme industriel.
L'eau sera turbinée 180 m plus bas dans une vallée (600 feet).
Les réservoirs d'eau en hauteurs seront au pied de chaque éolienne à raison d environ 38 000 m3 d'eau (10.6 millions de Gallons).
Devrait être opérationnel fin 2018
This Unique Combo Of Wind And Hydro Power Could Revolutionize Renewable Energy
Oct 16, 2016 by Tobey Grumet
Wind is a clean, cheap source of renewable energy, but it’s also fickle. You can never be sure whether the wind will blow. But engineers in Europe have now found a way to crack this shortcoming by combining it with hydropower. The big idea here is that the wind will generate electricity when it’s, well, windy, and the water will act as a giant battery that will discharge and modulate output when it stops blowing.
The German firm Max Boegl Wind AG approached GE Renewable Energy to collaborate on the first wind farm with an integrated hydropower plant in March. The four-turbine pilot project will be connected to the grid by the end of 2017, and the hydropower plant should be operational by the end of 2018.
These won’t be ordinary wind turbines. They will be the world’s tallest, standing 584 feet high when the blade is pointing straight up. The base of the turbines—the bottom 131 feet—will double as a water reservoir holding 1.6 million gallons of water, and the whole turbine will sit in another reservoir holding an additional 9 million gallons.
The setup essentially works as a hydro pump station (see image above). When electricity is needed, water flowing downhill from the reservoirs will power the hydro plant. When the energy supply is high, the hydro plant will pump the water back up the hill to the reservoirs and will act as the giant battery. The hydro plant will benefit from this arbitrage, making power when the price is high and using power when the price is low, while complementing the wind farm. The combination of the two power sources (which will work in parallel to each other) will ensure that electricity is always flowing from the plant.
For it to work, the wind turbines must sit at the top of a hill, and there must be room in the valley for a man-made lake — in this case 600 feet below the wind farm—that will store the water when it’s not being used by the turbines.
The Swabian-Franconian Forest, in Germany, proved the perfect location. Built into the hills will be a hydroelectric plant capable of producing 16 megawatts of power, while the wind farm on its own will produce 13.6 megawatts.
The team behind the farms says the innovative design provides a very fast increase in output, allowing the hydro plant to react immediately to fluctuations in the German energy market. “Germans in this area are known as tinkerers and inventors,” says Cliff Harris, general manager for onshore wind in EMEA at GE Renewable Energy. “So the mentality of this technology really fits with the population.”
http://www.gereports.com/unique-combo-w ... le-energy/
il y a des illustrations interessantes dans le lien mais trop grandes pour entrer ici.
voir aussi http://www.evwind.es/2016/11/03/germany ... ines/57807
moinsdewatt
x 554
par moinsdewatt » 15/03/17, 22:32
Les éoliennes se déploient près de la Haute-Loire
Avec 29 aérogénérateurs dispersés sur trois sites dans la montagne ardéchoise, EDF Énergies nouvelles gérera le plus grand parc de la région.
Le 27/11/2016
Les éoliennes sont situées en zone forestière. Photo Fabien HISBACQ
Elles sortent de terre depuis quelques mois. Certaines sont visibles depuis la Haute-Loire. Vingt-neuf éoliennes en tout. Si certaines pâles tournent déjà pour des essais, d’autres restent à monter. Leur mise en service est prévue pour le premier trimestre 2017. C’est EDF Énergies nouvelles qui exploitera ce parc étalé sur trois sites (treize éoliennes pour Saint-Étienne-de-Lugdarès et Le Plagnal, sous la forme d’une extension du site préexistant, huit éoliennes à cheval sur Lespéron et Lavilatte et huit autres à Issanlas).
Quatre kilomètres de piste ont été créés
Si la phase la plus compliquée reste le montage du projet (lire par ailleurs), celui des éoliennes n’en est pas moins spectaculaire. Ici et là, dans la forêt, des grues géantes installent mâts et pâles dans un ballet millimétré. Même l’acheminement du matériel est peu banal. Les mâts, par exemple. Ils sont fabriqués à Compiègne (Oise) par l’entreprise allemande Enercon et arrivent par tronçons en convois exceptionnels. Les éléments font d’abord un tour sur l’eau. En péniche jusqu’au Havre et en bateau spécial, L’Enercon Ship, jusqu’à Sète. Ce navire utilise quatre grandes voiles tubulaires rotatives pour se servir du vent comme force motrice (en complément du carburant). De l’Hérault, les éléments remontent ensuite vers l’Ardèche en empruntant l’A75.
Sur place, il faut aussi aménager le chantier, parfois en pleine nature. « À chaque fois que c’est possible, nous utilisons les pistes forestières existantes », explique-t-on chez EDF Énergies nouvelles. Quatre kilomètres de pistes ont quand même dû être créés. La moitié des arbres coupés sera replantée d’ici fin 2017 et les zones de chantier revitalisées avec des espèces locales. Quant aux tranchées, elles ont déjà un autre usage. « Le chantier permet l’accélération du déploiement du réseau haut débit. Le Syndicat Ardèche Drôme numérique utilise nos tranchées de raccordement pour installer les fourreaux qui accueilleront la fibre optique », précise l’entreprise.
De l’électricité pour 80 000 habitants
EDF Énergies nouvelles était déjà présent en Ardèche. L’entreprise exploite un parc à Freyssenet de 10 MW. En Haute-Loire, elle gère celui des Barthes (Moudeyres et Freycenet-la-Tour, 12 MW). Tout près d’ici aussi, elle a en charge un parc de 14 MW en Lozère (Lou Paou, Servières, Rieutort-de-Randon et Le Chastel-Nouvel). Parc dont l’extension est en développement. Le projet des Taillades (La Bastide-Puylaurent et Chasseradès, 27 MW) est, quant à lui « autorisé ». D’ici quelques années, EDF aura donc réussi une grosse percée dans la région sur un terrain souvent très glissant face à son principal concurrent, Boralex (parc d’Ally-Mercoeur).
La puissance totale du futur parc, 73,5 MW produit de l’électricité « pour subvenir aux besoins annuels d’environ 80 000 habitants », soit « l’équivalent de près de 25 % de la population ardéchoise ». Un argument de poids, même si la réalité est plus complexe puisque l’électricité produite en Ardèche sera « injectée sur le réseau national, comme toute la production française », précise l’entreprise. Dans les faits, « les flux d’électricité font que celle-ci est consommée au plus proche de sa production ». On peut donc dire que des foyers altiligériens seront sans doute alimentés par la montagne ardéchoise.
http://www.leprogres.fr/environnement/2 ... aute-loire
D'après La Tribune de ce jour sur EDF Energie Nouvelle , ce parc aurait été mis en service aujourd'hui. (le 14 mars)
moinsdewatt
x 554
par moinsdewatt » 26/03/17, 15:23
(France) Nouveau record éolien à 8.445 GW le Dimanche 05 Mars 2017 à 12h45
J' avais pas vu la journée du 27 fevrier !
Nouveau record éolien à 9.132 GW le Dimanche 27 Février 2017 à 13h30
et en prime 2.541 GW en solaire PV
moinsdewatt
x 554
par moinsdewatt » 18/04/17, 21:34
La Chine construit le plus gros parc éolien offshore du monde en 3 phases. La premiére phase de 100 MW est déjà réalisée.
100 autres turbines de 400 MW en cours d' installation, fin de la phase en oct 2017. Puis derniére phase de 300 MW pour 2018.
Total 800 MW.
China on track to build world’s largest offshore wind farm
April 13, 2017 evwind
State Power Investment Corporation (SPIC), one of the top five power generators in China, is making swift progress in raising its planned 800 megawatts wind power farm off the coast of eastern China’s Yancheng, Jiangsu province. Once completed, the farm will eclipse the 630 MW London Array as the world’s largest offshore wind farm. It is set to enter full operation in 2018.
Maturing technology and increasing competition have helped to reduce costs, making offshore power increasingly competitive. The push to expand offshore has been driven by the fact that many major economic hubs in China are located near the coast, analysts said.
The construction of Yancheng project will occur in three phases. The first 100 MW installed capacity consists of 25 4.0 mW Siemens turbines, which are already spinning, occupying 20 square kilometers of water just 10 meters from shore. By March 2017, this portion of the project had generated 190 million kWh of electricity.
The second phase of construction is currently underway, set to boost installed capacity by another 400 MW by October 2017 using 100 wind turbines. A 2*240,000 kVA transformer will be used in its floating booster station designed by Danish firm Ramboll. Once installed, it will become Asia’s largest offshore booster station and China’s first booster station to follow European standards.
Due to start in the second half of 2017, the third phase of the project is situated further south. Wind turbines with 300 mW of capacity will be erected in the water at a depth of 18 meters, 36 kilometers from the shore. In order to benefit from the annual average wind speed of 7.43m/s, the yearly utilization time of the turbines will be 2,545 hours. This phase of construction is expected to be completed in 2018.
SPIC is a global green energy provider with a total installed capacity of 117 gW. It operates in the industries of coal, aluminum, logistics, finance, environmental protection and advanced technology. It maintains a presence in 36 countries and regions, including Australia, Chile, Malta, Japan, Brazil, Turkey and Vietnam.
http://www.evwind.es/2017/04/13/china-o ... farm/59467
Swiltar
par Swiltar » 20/04/17, 10:20
Personnellement, je pense que c'est une nécessité de passer au 100% énergies renouvelables le plus vite possible, les éoliennes devront donc avoir toute leur place (http://www.jam.fr/users/witar.sylvie).
Je trouve ça joli en plus.
moinsdewatt
x 554
par moinsdewatt » 20/04/17, 20:02
Faut pas abuser non plus.
Aux USA.
Sinon en vraiment joli, il y a ceci :
Barton Wind Farm, Worth County Iowa
goodgerald
par goodgerald » 22/05/17, 10:17
je trouve les éoliennes une méthode intéressante mais pas et utile, mais il me semble que parfois les investissements dans ce type d'énergie sont plus grands que l'effet de sortie, ce qui peut provequer des pertes financières.
Je pense que cela peut être dû à cause de l'instabilité et l'inconstance du vent.
Mes articles sur les appareils de climatisation et chauffage à la maison. N'hésitez pas à donner votre avis sur mon travail!
Mon nouveau blog anglais:
https://www.bestadvisor.com/water-filter-systems
moinsdewatt
x 554
par moinsdewatt » 06/06/17, 20:23
Superbe production en éolien en France cette journée avec une moyenne d' environ 7 GW !
http://www.rte-france.com/fr/eco2mix/eco2mix-mix-energetique
à 14h production de 12.3 GW éolien + solaire !
x 11025
par Christophe » 07/06/17, 22:18
Bien bien!! Mais la France peut mieux faire :cheesy:
Il y a quelques semaines l'Allemagne était alimentée au 2/3 aux sources renouvelables pendant quelques heures durant un week-end...
x 11025
par Christophe » 07/06/17, 22:19
moinsdewatt a écrit :Faut pas abuser non plus.
Aux USA.
C'est quoi qu'est le plus moche selon toi sur cette photo?
Les éoliennes ou les lignes HT? :cheesy:
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 189 invités
