Inscrit le: 02 Mar 2005 Messages: 52 Localisation: Krakow,Poland
Posté le: Lun 24 Mar 2008, 14:30 Sujet du message:
Litlle HorsePowerMeter
Tongues in engines manner of measurement of amount of mechanical horse.
Each engine owns invariable parameters about definite , like :
Sum of inertia mass, sum inertia springs, chains ,valves,etc.
Each model of engine has this parameters exactly SAME !!
And if for example, we want it without load for 4000 RPM ,at same time , we need exactly SAME horsepower.
It is principle my idea: Horse Power Meter.
Manner of measurement Horse Power:
Car is stop !!
We have running engine in idle RPM.
We need only same impulse classic RPM meter
Next we push and press i electronic meter switch "measurement"
Next we must push throttle in FULL .
Engine go to eg 5000 RPM.
Electronic measurement TIME with special SOFT , how long engine going measurement period 3000 rpm to 4000 rpm . This TIME are equivalent horsepower of engine.
Little power -long time , normal power - short time
Idea in diagram:
Next diagram electronic of Horsepower Meter, can made little 8 -bit processor eg. AT2051. Small individual Soft for each model of engine:
Engine is gauged in its time of measurement of force LOAD his own.
And it is not necessary has drive testing your car.
Happy Easter
Andrew _________________ Andrew Feliks
Posté le: Mer 07 Mai 2008, 02:00 Sujet du message:
On one of aerial forum, describing my horse power meter, it re-wrapped in discussion for transmit force for transmission in helicopters theme limitation , very often.
I read this forum and , I has been orientated , that transmission is critical element in helicopter most
Sometimes. at creation of new invention, inspiration takes place at I safety of user most important
There is so and this time.
Understand how as critical thing beginning, try to omit she completely.
My constructions for carrying half- rotary engine directly try to joint impeller of helicopter, with out any transmission. In order to get low turns properly, I must use engine about outsized jumping capacity, and low rpm. My half -rotate engine, is accuracy, and size are reasonable.
Second ,safety important , are diesel fuel in this low rpm engine. Summary I increase safety twice.
It try to make similar to main parameters " " Chinook”.
Toutes les heures sont au format GMT + 2 Heures Aller à la page Précédente1, 2, 3 ... 14, 15, 16
Page 16 sur 16
