| Recherche et inscription à notre newsletter. Inscription aux forums, cliquez-ici |
| Auteur |
Message |
Remundo Econologue expert
Inscrit le: 15 Oct 2007 Messages: 2207 Localisation: Clermont Ferrand
| Revenir en haut de page |
nlc Econologue expert
Inscrit le: 10 Nov 2005 Messages: 1690 Localisation: Nantes
Offres professionnelles Connectez vous pour supprimer ces annonces |
Posté le: Sam 26 Avr 2008, 11:24 Sujet du message: |
Oui, ça c'est pas mal (extrait de ton lien)
Figure 4. Thermoacoustic engines are similar to optical lasers in that both types of apparatus amplify standing waves set up within resonant cavities. In a ruby laser (top), for example, energy is added by means of a flash tube, which creates a "population inversion" of electron energy levels. In the thermoacoustic analogue (bottom), energy is injected into the cavity using the heated stack, which creates a nonequilibrium temperature distribution.
Tom Dunne _________________
http://sycomoreen.free.fr
Posté le: Sam 26 Avr 2008, 11:30 Sujet du message: |
ça aussi c'est très bon... Le stack jouerait le rôle de régénérateur... il il faudrait chauffer le tube d'un côté, et refroidir de l'autre...
Figure 7. Stirling cycle contains four distinct steps—compression, heating, expansion and cooling—which produce a characteristic set of changes in pressure and volume (right). In a simple, two-piston Stirling engine (directly below), the compression step (1) keeps one piston fixed as the other moves inward, the heat of compression being rejected into the adjacent cold reservoir. The next step (2) produces constant-volume regenerative heating, as both pistons move simultaneously, forcing cool gas through the porous regenerator, which was heated during the final step of the last cycle. Next (step 3), heat from the hot reservoir causes thermal expansion of the gas, which forces the adjacent piston to move outward. Finally (step 4), both pistons move together to create a constant-volume regenerative cooling of the heated gas. The changes in pressure and gas velocity within the regenerator of such a Stirling engine mimic the relationship seen in a traveling acoustic wave, where pressure and gas velocity move up and down in phase (bottom pair of panels).
Posté le: Sam 26 Avr 2008, 11:32 Sujet du message: |
Je mets ça aussi !
Figure 8. Traveling-wave heat engine that Peter H. Ceperley envisioned more than two decades ago amounts to a loop of gas-filled pipe with one or more porous regenerators inside. Heat exchangers attached to each regenerator supply heat or carry it away, setting up thermal gradients (solid arrows). In this configuration (adapted from Ceperley's 1979 patent), one regenerator is meant to amplify the traveling acoustic wave (dashed arrow), while the second provides useful cooling. Although Ceperley was never able to construct a working traveling-wave engine, T. Yazaki and three Japanese colleagues described in 1998 their success in building such a device to compare the properties of traveling- and standing-wave thermoacoustic engines.
Capt_Maloche G.I.S.M.E.
Inscrit le: 29 Juil 2006 Messages: 2693 Localisation: Ile de France
C'est le principe du laser
par contre côté rendement, un réfrigérateur traditionnel à compresseur à un COP de 4, alors qu'avec la thermo-acoustique on sera en dessous de 1
faudra choisir  _________________
OUCH, OUILLE, AÏE, AAHH! ^_^ --
"La consommation s'apparente à une recherche de consolation, un moyen de remplir un vide existentiel croissant. Avec, à la clé, beaucoup de frustration et un peu de culpabilisation, accrue par la prise de conscience écologique." (Gérard Mermet) |
Posté le: Sam 26 Avr 2008, 11:33 Sujet du message: |
Salut Captain !
Et oui, côté rendement, le bât blesse apparemment... mais il y a de la simplicité technique, c'est ce que Nlc recherche  _________________
Posté le: Sam 26 Avr 2008, 11:34 Sujet du message: |
| Remundo a écrit: |
excellent ! ç'est le principe du pseudo stirling sur la photo de lapage précédente _________________
Posté le: Sam 26 Avr 2008, 11:40 Sujet du message: |
Enfin page 5, ils disent avoir trouvé un truc, un genre de "valve anti-retour"... qui mettrait les performances au niveau des moteurs actuels...
http://www.americanscientist.org/template/Asset...1006/page/5#23077
| American Scientist a écrit: |
| Once we realized what was happening, it was easy enough to correct the problem. One solution (which Ceperley had suggested years earlier for his circular design) would be to add a flexible membrane that passed acoustic waves yet blocked the continuous flow of gas. But prior experience with such membranes led us to believe that it would be hard to engineer something sufficiently robust to hold up over time. So instead we added a jet pump (asymmetric openings that allow flow to pass in one direction more easily than the other) to create a slight back-pressure in the loop, just enough to cancel the streaming. And we were pleased to find that the efficiency of the engine improved markedly. At best it ran at 42 percent of the maximum theoretical efficiency, which is about 40 percent better than earlier thermoacoustic devices had achieved and rivals what modern internal-combustion engines can offer. |
_________________
Forum énergies, maison, solaire, chauffage, bois, isolation, écologie, économies et moteur pantone Index du Forum
-> Les énergies renouvelables : solaire, geothermie, bois énergie |
Toutes les heures sont au format GMT + 2 Heures Aller à la page Précédente 1, 2, 3 ... , 9, 10, 11 Suivante
| Page 10 sur 11 |
| Sujets similaires à lire |
| Sujet |
Auteur |
Forum |
Réponses |
Posté le |
Petites idées : amélioration du génér... |
xboxman4 |
Moteurs ou procédés surunitaires, débat et idées ? |
7 |
Mar 12 Aoû 2008, 16:16  |
PANTONE ARGENTINO AVEC GÉNÉRATEUR DE ... |
rodibruno |
Expérimentations de moteurs Pantone |
5 |
Jeu 10 Avr 2008, 04:27  |
generateur styrling |
rodibruno |
Libéralisation de l'énergie: électricité et gaz |
1 |
Mar 26 Fév 2008, 04:33  |
Parc marin générateur d'énergie : JT ... |
jean63 |
Actualités et nouvelles sur l'environnement: presse, TV, médias... |
5 |
Mar 15 Jan 2008, 00:06  |
Capteur solaire rotatif générateur de... |
binbins4 |
5 |
Lun 08 Oct 2007, 20:57  |
