New 4 stroke engine (en anglais)
- inventor
- J'ai posté 500 messages!
- x 82
Did you know that it looks like the latest engine to produce electricity using any fuel, such as coal dust. Attached to the treadmill, skip step steam,,,
The end of the treadmill must be about 1 Mach speed, which at the shoulder of 50 meters is normal ... every second ..
http://www.youtube.com/watch?feature=player_embedded&v=CGcRgEuCocQ
It's not like we all have to fly, but the current a good thing ...
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
Here is a reworked so as not to put unnecessary drag .. A bit like a UFO. Still on the edge of the "plate" can fasten some neodymium magnets ....
With these dimensions of 10 MW ....
In preparation for the new job of atomic physics, they can calculate the efficiency of the this power plant ...
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
This treadmill UFO version of ramjet engines, would work best as an MHD generator. Its efficiency apparently comes to 60% or more has no moving parts. At 1 m plasma jet should be good.
The rest of you can generate in the traditional way, which would help stabilize the rotation ...
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
So interesting what you can find in my archives. The oldest Radioamator I found in my ...
Google translated :
"According to information published in one of the writings of English - has been developed by researchers at the concept of electricity generation by passage of ions and electrons with very high speed through a magnetic field
The practical implementation of this method that was based on Plasma gas forcing by the strong magnetic field. Electrical power of 1000 KW can be obtained by passing the said plasma at 3 times the speed of sound, the magnetic field of 1 meter long between the poles of a magnet at a distance from each other by about 15 cm. No, you would need the boilers and steam turbines. Previous experiments have generated so far a small amount of electrical energy. Achieving the full effect expected after several years of further intensive tests conducted"..
Andrew
Google translated :
Andrew
Andrew Feliks
- inventor
- x 82
Maybe the exhaust manifold to the F1 wear a magnet and additional energy (electricity) have?
Do not give me those numbers alone ... When linearly decreased as the amount of energy ... it
5 cm in diameter and 1 meter length of pipe that is 10 times less that is = 100 KW
The flow rate is not 900 m / s just say 200 m / s that is to say 4, 5 fold less = 22KW ... For each cylinder?
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
How can I bypass the statutory 20 mm in diameter ... and we have a little more air in the engine intake manifold
http://sae.wsu.edu/media/0708car/08-03-10/
And here, if the exhaust pipe wrap neodymium magnets .... I have a small MHD...
http://sae.wsu.edu/media/engine/target0.html
Andrew
Andrew
Andrew Feliks
Revenir vers « Econology forum in english »
