And in the meantime since the formation of the ideas, changes a lot. For example, go beyond the "magic circle of the cylinder" was the hardest thing.
When I discovered it, a new type of timing, was the new 4 stroke engine:
Regards Andrew
New 4 stroke engine (en anglais)
- inventor
- J'ai posté 500 messages!
- x 82
I think the era of steam comes to an end. At most in obsolete nuclear power plants will be still used.
Half supports the engine has one very big advantage. Piston not friction on the walls of the "cylinder""Only the seals frictions cylinder
Thanks to these properties, the engine may be running on ... the coal dust.
Rudolf Diesel's first engine was built just on the coal dust, but unfortunately zacierał is at work. In the case of half rotate, will not look any login problems.Simply does not have any large surface friction
Only the directory should be chosen for personal seal. Each round you can straighten lines, of course, resistant to coal dust.....
http://www.youtube.com/watch?v=G6hwiz0QXsE
http://www.passerotti.com.pl/page/pol/download/549P.pdf
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
[quote name='Wuzak' post='5587386' date='Mar 15 2012, 08:26']Will sufficient heat be generated in the exhaust to be used ina combined cycle situation?[/quote]
Yes, combined cycle, but also the latest trends ...
http://www.gizmag.com/thermoelectric-cars-improve-mpg/10928/
And since it has to work at the coal face powder (same what they use today's power plants for combustion in boilers).
can seals with carbon, similar to the scrubbing of electric motors
http://hariramco.com/carbon-brushes.html
http://www.dpaonthenet.net/article/47129/C...ompressors.aspx
Star engines were characterized biggest always force density
Below picture of the star half rotate around 10 (40) with "cylinders". for the transparency of the picture one can see only 3 additional "cylinders" more than is at the animated film.
One can also see dimensions of the whole of the engine in the assumption that every cylinder has such dimensions for the picture half rotate with the set connecting rod of the Sulzer D= engine of 900 mm and stroke 2500 mm .
So 10 (40) "cylindrical" engine half rotate about the same working capacity in comparing to the Sulzer 10 engine cylindrical on the picture below .
Sulzer: 10 Cylinders 20 m long , 15 m hight , 1500 Ton weight
Half rotate star : 10(40) "Cylinders" 4,5 m diameter , 4,5 m long
about 70 ton weight.
And most importantly.. Since in the engine half rotate mass innertia are several times Sulzer smaller than in the engine, engine half rotate can work with the much greater rotation speed.
Slzer : 102 RPM 60 000 KW
Half rotate 250 RPM 150 000 KW
In same intake work volume .
And now, the efficiency of the engine, due to the friction of the walls of the cylinder to rise about 5%. That is, it is the most efficient machine for the heat, whose efficiency exceeds 50% of the.
http://www.theoildrum.com/node/2249
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
Fukushima:
"Gundersen: Slowly over the last couple of weeks the hydrogen has continued to build up inside the containments…
It’s coming from the bombardment of water from all the radiation that’s in the core. So a radioactive particle that’s just h20 splits to crank out the hydrogen.
It was incredibly low, now it’s up to about half a percent hydrogen.
So the trend is worrisome.
It has to get to 4% though… before it explodes.
So there’s still a margin to prevent an explosion.
So the trend, why is the hydrogen going up, is worrisome…"
Can hydrogen be requested to give away progressively by using such a method, similar to the disposal of teh hydrogen when charging?
http://bater.pl/en/recombination-plug
Anything to the atmosphere, you don't need to sit in the application of this method. Everything is in the reactor, and the hydrogen is not…
Nothing to allow passage to the atmosphere.
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
http://www.powermag.com/blog/index.php/ ... -in-japan/
Fear think about what would happen, if not given these five cents....
Andrew
Is it possible Tsunami from the Mainland ???
Yes of course ...
As such, things appear to the local river.....
Wishing you to never be so does not become.
anxious Andrew
Andrew
Yes of course ...
anxious Andrew
Andrew Feliks
- inventor
- x 82
http://www.mnn.com/green-tech/gadgets-e ... es-highway
http://seattletimes.nwsource.com/html/l ... de11m.html
If not yet, unfortunately, there was no Internet....
http://www.youtube.com/watch?v=bvCkH5yLoYo
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
http://www.guardian.co.uk/world/vide...-reactor-video
17 March 2011
And faith in the power of the defence forces....
Defence force always better than the force of reason...
Andrew
17 March 2011
Andrew
Andrew Feliks
- Remundo
- x 5714
Hello Andrew,
Nice technical descriptions.
I haven' seen the video of the crash for the helicopter. Tragic, but perhaps this death for the pilots was better than longly suffering from a cancer due to overdoses of radiation, right up of the radioactive boiling corium...
For your last post, the link to Guardian doesn't work...
Revenir vers « Econology forum in english »
