Bonjour et bienvenue sur ce forum! Je suis un des 1er forums francophones et indépendant sur l'écologie, le chauffage, le thermique, l'isolation, les énergies renouvelables ou fossiles et nucléaire, le bricolage et la maison, la mobilité et nouveaux transports, la société, l'économie et la finance durables... Je suis visité et animé par des passionnés, experts, spécialistes ou professionnels... Si vous avez une question ou une réponse, n'hésitez pas à me rejoindre en vous inscrivant ici (être membre = suppression des publicités et navigation facilitée)
| Auteur |
Message |
inventor J'économise des grammes de CO2
Inscrit le: 02 Mar 2005 Messages: 296 Localisation: Krakow,Poland
Posté le: Mar 28 Fév 2012, 17:31 |
And in the meantime since the formation of the ideas, changes a lot. For example, go beyond the "magic circle of the cylinder" was the hardest thing.
When I discovered it, a new type of timing, was the new 4 stroke engine:
Regards Andrew  _________________ Andrew Feliks |
| Revenir en haut de page |
Posté le: Jeu 01 Mar 2012, 13:11 |
My 6 cylinder boxer..
Can have two times less cubic capacity, because that is two times smaller turnover at the flywheel.
Liens commerciaux
Posté le: Lun 12 Mar 2012, 04:51 |
I think the era of steam comes to an end. At most in obsolete nuclear power plants will be still used.
Half supports the engine has one very big advantage. Piston not friction on the walls of the "cylinder""Only the seals frictions cylinder
Thanks to these properties, the engine may be running on ... the coal dust.
Rudolf Diesel's first engine was built just on the coal dust, but unfortunately zacierał is at work. In the case of half rotate, will not look any login problems.Simply does not have any large surface friction
Only the directory should be chosen for personal seal. Each round you can straighten lines, of course, resistant to coal dust.....
http://www.youtube.com/watch?v=G6hwiz0QXsE
http://www.passerotti.com.pl/page/pol/download/549P.pdf
Posté le: Dim 18 Mar 2012, 01:17 |
[quote name='Wuzak' post='5587386' date='Mar 15 2012, 08:26']Will sufficient heat be generated in the exhaust to be used ina combined cycle situation?[/quote]
Yes, combined cycle, but also the latest trends ...
http://www.gizmag.com/thermoelectric-cars-improve-mpg/10928/
And since it has to work at the coal face powder (same what they use today's power plants for combustion in boilers).
can seals with carbon, similar to the scrubbing of electric motors
http://hariramco.com/carbon-brushes.html
http://www.dpaonthenet.net/article/47129/C...ompressors.aspx
Star engines were characterized biggest always force density
Below picture of the star half rotate around 10 (40) with "cylinders". for the transparency of the picture one can see only 3 additional "cylinders" more than is at the animated film.
One can also see dimensions of the whole of the engine in the assumption that every cylinder has such dimensions for the picture half rotate with the set connecting rod of the Sulzer D= engine of 900 mm and stroke 2500 mm .
So 10 (40) "cylindrical" engine half rotate about the same working capacity in comparing to the Sulzer 10 engine cylindrical on the picture below .
Sulzer: 10 Cylinders 20 m long , 15 m hight , 1500 Ton weight
Half rotate star : 10(40) "Cylinders" 4,5 m diameter , 4,5 m long
about 70 ton weight.
And most importantly.. Since in the engine half rotate mass innertia are several times Sulzer smaller than in the engine, engine half rotate can work with the much greater rotation speed.
Slzer : 102 RPM 60 000 KW
Half rotate 250 RPM 150 000 KW
In same intake work volume .
And now, the efficiency of the engine, due to the friction of the walls of the cylinder to rise about 5%. That is, it is the most efficient machine for the heat, whose efficiency exceeds 50% of the.
http://www.theoildrum.com/node/2249
Posté le: Jeu 24 Mai 2012, 12:48 |
Fukushima:
"Gundersen: Slowly over the last couple of weeks the hydrogen has continued to build up inside the containments…
It’s coming from the bombardment of water from all the radiation that’s in the core. So a radioactive particle that’s just h20 splits to crank out the hydrogen.
It was incredibly low, now it’s up to about half a percent hydrogen.
So the trend is worrisome.
It has to get to 4% though… before it explodes.
So there’s still a margin to prevent an explosion.
So the trend, why is the hydrogen going up, is worrisome…"
Can hydrogen be requested to give away progressively by using such a method, similar to the disposal of teh hydrogen when charging?
http://bater.pl/en/recombination-plug
Anything to the atmosphere, you don't need to sit in the application of this method. Everything is in the reactor, and the hydrogen is not…
Nothing to allow passage to the atmosphere.
dedeleco Econologue expert
Inscrit le: 16 Jan 2010 Messages: 9068 Localisation: Plus sur ce forum...
Posté le: Jeu 24 Mai 2012, 13:05 |
In principle, French nucleocrats, say that there was such similar H recombination plugs inside French reactors, long before Fukushima !!!
Is it really true and well placed at the right position ???
Since Three Miles Islands, it is evident that it is very necessary !!!! |
Posté le: Sam 23 Juin 2012, 22:15 |
http://www.powermag.com/blog/index.php/2011/03/...r-power-in-japan/
Fear think about what would happen, if not given these five cents....
Andrew
Is it possible Tsunami from the Mainland ???
Yes of course ...
As such, things appear to the local river.....
Wishing you to never be so does not become.
anxious Andrew  _________________ Andrew Feliks |
Remundo Modérateur sympa (G.I.S.M.E.)
Inscrit le: 15 Oct 2007 Messages: 6347 Localisation: Clermont Ferrand
Posté le: Jeu 28 Juin 2012, 08:19 |
Hello Andrew,
Nice technical descriptions.
I haven' seen the video of the crash for the helicopter. Tragic, but perhaps this death for the pilots was better than longly suffering from a cancer due to overdoses of radiation, right up of the radioactive boiling corium...
For your last post, the link to Guardian doesn't work... _________________
Liens commerciaux
-> Econology forum in english |
Toutes les heures sont au format GMT + 2 Heures Aller à la page Précédente 1, 2, 3 ... 42, 43, 44 ... 47, 48, 49 Suivante
| Page 43 sur 49 |
| Sujets similaires à lire |
| Sujet |
Auteur |
Forum |
Réponses |
Posté le |
Moteur scuderi split cycle engine |
chatelot16 |
Nouveaux transports: moteurs, pollution, technologies, politiques, organisation... |
2 |
Jeu 16 Mai 2013, 15:56  |
Rotary Stirling engine by Andrzej |
Remundo |
15 |
Lun 03 Jan 2011, 14:14  |
The "FF" engine by SHI ZHE |
FUHANDAIGOU |
81 |
Jeu 11 Mar 2010, 10:14  |
Mister Pantone interview (en anglais) |
gilgamesh |
Expérimentations et montages de moteur pantone |
2 |
Lun 06 Juil 2009, 23:29  |
Un site de référence et un livre à té... |
jam |
Energies renouvelables: éolien, hydraulique, geothermie, énergies marines, biomasse et biogaz |
0 |
Jeu 21 Mai 2009, 21:53  |
Les téléchargements:
Les articles:
Les nouvelles:
- 05/01: Conférence de Pierre Larrouturou: éviter le krach ultime...
Annoncer ou faire votre publicité sur Econologie.com?
Econologie.com est partenaire de Roulez à l'huile: Oliomobile.org et Isolation, chauffage et habitation économe
