Hi Remondo!
The problem is not to create the motor but the electronic which is very hard to conceive, that's why this is very expensive.
New 4 stroke engine (en anglais)
- Remundo
- x 5244
Yes Alain,
and that's why I've worked hard to get hyper compact engines, in order to use one "combustion" chamber as a pneumatic chamber, which stores the kinetic energy while braking, and sends it back while relaunching...
And pneumatic devices doesn't need complex electronic or power thyristor, and is instantaneous both at storage that at expanding
It just needs a system of valves... Do you have seen the very last works of Sycomoreen on motors & pumps, the anti-friction epicyclic rotary valve ?
Nevertheless, electric recovery are a also a nice way of thinking and experimenting, because at present, there's no compact engines on the market, nor pneumatic storage for vehicles
Hi Remondo!
The problem is that you need a bigger pump in decelerating mode than accelerating and will create much heating air that you will lose for nothing, but this heat can be stored to heated the chamber to increase the output of the air motor.
So you need 2 motors/pumps to used in serial like a 2 stage High pressure for the first stage then second stage for low pressure hooked after the first, for decelerating you use both in pump hooked in parallel.
I agree that it can work but surely not as efficient than a eletric system, the advantage is the cost which is very low in comparison to electric.
Alain
Alain
- Remundo
- x 5244
Hi Andrews, it seems to me that you're polish, not very far from Ukrain; and perhaps do you have eaten some non conventional mushrooms
To be more serious, I'm not quite informed about the state of the art to get power from waves in the sea... Do you have done some research about that ? How do your oscillating dynamos take place from a technological/historical point of view ?
- inventor
- J'ai posté 500 messages!
- x 82
Remundo a écrit :Hi Andrews, it seems to me that you're polish, not very far from Ukrain; and perhaps do you have eaten some non conventional mushrooms
Technological and historical view: This my personal idea , publication started at http://forums.autosport.com/index.php?showsujet=74960&st=160
Congratulations please to e mail : andrew@new4stroke.com
Remundo, this view of only energic HALF rotate stepper engine (left , right,left, right) video with to bulbs .One coil have diode and capacitor., another one coil no have.
http://www.new4stroke.com/stepper.wmv
You can made this demonstrate , using old stepper engine of old computers printer. Value elements on image:
next oscillating dynamo principe , are in same diode, but valave of water, when pumps water too hight reservoir( water capacitor )
Some research need antique people ask. They are pumps water to his poles . And Arhimedes laws are explained
Regards Andrew
Andrew Feliks
- inventor
- x 82
Now I will describe the entire technology of modification swimmer.
Made a cheap swimmer :
1.To buy old sea containers.
2. Weld some diagonals new part too to improve the stiffness,
3. To paint the container this way modified with method of the bath in rustproof paint.
4 . Put for means container maximum polystyrene foam packed into strong plastic sacks.
5. To close the container tightly.
5. Through the small hole to fill up under the pressure with the foam polystyrene foam.
(automatically expanded one's volume)
6. We have a long time live swimmer weight about 3000 kG , and volume 33 m^3
Sum we have 30 000 KG (30 Ton) displacement force each .
Redy too using In oscillatory dynamo or water pumps make energy.
Regards Andrew
Regards Andrew
Andrew Feliks
Revenir vers « Econology forum in english »
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 96 invités
