The Fuelless Gravity
Motor
is what
I invented before I discovered the Fuelless
Engine! You
will not be able to run a car with it, but you can build one to generate
AC or DC electricity for your home. This invention is basically
like a windmill generator but does not require wind to make it run. Instead it uses
gravity, inertia and leverage as its main sources of power as well as a small
input of electrical power to start and keep the free energy reaction going. (
1200V dc pulses x .10 milliamps ). Most free energy devices have to
have some kind of input energy to get the chain reaction going. The
only free energy device that I have seen running without a small
input of energy, is an all permanent magnet motor ( our Fuelless
Engine is also considered as a permanent magnet
motor ). A free energy
permanent magnet motor needs no outside source of energy, it uses
nothing but magnets to run itself. ( See our plans #376 for $19.95 )
I have spent over 7 years developing this gravity
motor, and all who have seen it run are amazed!
The plans are well illustrated,
and supplies are easy to find in most hardware stores
and on the internet. Parts and supplies can be ordered
by phone and mailed right to your front door from any
internet supplier. This
device is easy to build! The longer the arms are built the more
horsepower and torque you will get at the rotor shaft area as well as adding
more weight to the end of the arms to increase the torque leverage area.
These plans also show you
how to test the mechanical structure of the device by using an air
compressor. You would want to make sure that all of
the nuts and bolts are in place and will not fly apart during
operation, since the unit is a very powerful and heavy
motor device.
" David Waggoner "
_________________________________________________________________________________
Homeowners or Farmers! By using our simple
design you can make the arms of this motor as tall
and or as
wide as your home, garage or barn. Add 33 to 100 lbs to the end of the
slider arms and the torque at the motor
shaft will be powerful enough to turn a
large low rpm AC or DC generator!
Great for indoor garage walls or outdoor operation.
This is not the actual
gravity motor, but is an animation to help teach you the
basic function of our motor.
So how does it work?
“The motor turns counter clock wise.
The arm is then in perfect balance position at the 6:00 and the 12:00 positions.
As it continues to turn past the 12:00 position the leverage arms both move to
the left about 10 to 12 inches. This creates an OFF BALANCE and rotates the heavy steel flywheel until the off balanced
arm reaches the 6:00 position. At that point a very high efficient / free energy
solenoid coil kicks in and pushes the arms back up into a perfect
balanced position and they continue to rotate back to the 12:00 position.
Then the process starts all over again - this is all done very quickly!”
“Our special high efficiency free energy solenoid coil
only comes on for a split second (at 6:00) and quickly
goes off. The input coil consumes only a small amount of
amperage to keep
it running! The rpm's can be adjusted. Our first prototype was very
easy to make, we simply used a bicycle wheel to prove that it worked and then went
on to build a bigger prototype.
Free
Electricity for your Home!
You may even be able to use our gravity motor design to run a low rpm windmill
generator to keep up a 12V DC deep cycle battery bank ( or use our low rpm
high efficiency SP500 generator ).
The battery bank is then connected to a 115V ac inverter which converts the 12V
DC into 120V
AC
to help run lighting and appliances in your home.
The
Gravity Motor uses balance as its main force of power and unlike
many so-called gravity motors out there, This one really works!
In 1995 we did our own
patent search and found
no other Gravity Motor like this.
It is easy to build and will amaze all your friends!
#FGE2
Fuelless Gravity Motor Plans $16.95
Instant Download!
#FGE3V Fuelless
Gravity video............$19.95
Instant Download!
Now
Available!
All 34 plans and 7 videos as seen on this website!
Also
includes the SP500 Generator plans for FREE!
You save over
$351.00
Click
here for a complete list of what you will receive.
CD 1
BASIC
Package
Excluding M2 plans
)..................................Only
$300.00
USD
This basic package includes only 33 plans and 4 videos
Instant Download!
CD 1 GOLD
Package (
Includes Our New!
Fuelless Engine M2 )..............Only $475.00 USD
This package includes everything seen on our website! All 34 plans
and 7 videos
Instant Download
& By Mail On CD!
Or Call: 1-812-945-5839
Office hours: 9 am - 5 pm New York Time
NOTICE! If you have already
purchased plans from us before, then you can deduct the amount you paid from the cost of the CD Package 1,
by request only.
ORDER BY
MAIL:
We accept personnel checks (USA only )
- Postal Money Orders or bank checks in US Dollars!
Creative Science and
Research PO BOX 557 New Albany Indiana 47151-0557 USA
Please add $14.95
for shipping US or outside the USA.
Printable Order Form
Return to top of page
Site Map --
Contact Us --
About Us
The Fuelless Engine Plans
The SP500 Generator
CD Package 1
--- Letters From Customers
Free Energy Catalog
The Fuelless Heater Plans ---
Windmill Generator Plans
--- HV Power Supply
--- High Voltage Capacitors
--- Fuel
From Water Plans ---
Homemade Battery Plans
Free Energy From The Earth
Solar Cell Plans ---
Nikola Tesla
Click
here to pay $14.95 shipping cost so we can mail you your order on
computer CD.
DOWNLOAD INFORMATION
Please allow 1 business day or less, for us to send you the download
links to your e-mail address.
