Horse mill
From Wikipedia, the free encyclopedia
Donkey mill at La Alcogida Ecomuseum in Fuerteventura
A horse mill is a mill, sometimes used in conjunction with a watermill or windmill, that uses a horse engine as the power source. Any milling process can be powered in this way, but the most frequent use of animal power in horse mills was for grinding grain and pumping water. Other animal engines for powering mills are powered by dogs, donkeys, oxen or camels. Treadwheels are engines powered by humans.
History[edit]
Horse or donkey-powered stone mills at Pompeii.
The donkey or horse-driven rotary mill was a 4th-century BC Carthaginian invention, with possible origins in Carthaginian Sardinia.[1][2] Two Carthaginian animal-powered millstones built using red lava from Carthaginian-controlled Mulargia in Sardinia were found in a 375–350 BC shipwreck near Mallorca.[2] The mill spread to Sicily, arriving in Italy in the 3rd century BC.[1] The Carthaginians used hand-powered rotary mills as early as the 6th century BC, and the use of the rotary mill in Spanish lead and silver mines may have contributed to the rise of the larger, animal-powered mill.[3] It freed the miller from most of the heavy burden of his task and greatly increased output through the superior stamina of horses and donkeys over humans.[1]
Gallery[edit]
Horse mill at Beamish Museum[edit]
This horse mill has not been used since about 1830 when it was superseded by portable engines. It was rescued from Berwick Hills Low Farm in Northumberland by the museum, repaired and set up in their own gin gang at Home Farm as a non-functioning exhibit. The top of the mill's main vertical axle and the end of the main drive shaft are pivoted at the centre of their own separate tie beam which is below and parallel with the main roof tie beam, and set in the gin gang's side walls at either end. The mill's tie beam has to be stabilised with two massive oak beams which run, either side of the drive shaft, from tie beam to threshing barn wall. A large and basic engine like this can create great stresses from the torque engendered.[4]
Mill construction[edit]
This four-horse mill is based on a central, vertical, heavy, 10 feet (3.0 m) high, oak axle, with its base pivoting on an iron framework set in the middle of the gin gang floor. Its top end pivots under the mill's own tie beam (if it didn't, it would fall over) but the tie beam cannot rest on the pivot, or the mill would not turn. The main axle supports around its top end the main, 6 feet (1.8 m)-diameter, horizontal gear wheel, with the teeth on the top surface. The main drive shaft, a massive oak pole, is girthed at one end by a secondary gear wheel which lies on the main gear wheel, thus turning the main drive shaft on its long axis. The main drive shaft runs from the main gear wheel through a hole in the threshing barn wall and in the barn it powers the threshing machine and other machines via further cogwheels and belts. Such a machine would create great torque stresses, and if it were ever to work again it would require re-engineering to ensure smooth and safe running, and beams which are seasoned and not cracked.[4]
Horse power[edit]
This is a powerful horse mill for four horses; probably English ponies, as modern heavy horses were not yet fully bred in the 1830s. Each of the four heavy oak beams connecting the central axle to the four horse shafts runs from beside the axle to the under-surface of the main gear wheel, and crosses the other three in a grid pattern between the axle and gear wheel, thus supporting the gear wheel and creating a rigid structure at the same time. They project for many feet beyond the main gear wheel, and require wooden stretchers to stabilise them. From the ends of these beams hang the horse shafts. The bottom ends of these shafts are quite low, which may indicate the use of ponies rather than early heavy horses.[4]
Horse gin at Nottingham Industrial Museum[edit]
A horse gin is on display at the Nottingham Industrial Museum. It was constructed in 1841 to sink the Langton Colliery shaft and moved in 1844 to Pinxton Green Colliery. It was still working in 1950 and it was erected in the museum in 1967. It was used at a pit head to raise coal to the surface. The Nottingham mines were shallow, coal was moved to the shaft on a sled, which was raised in a cage by a rope attached to a rope drum that was turned by the horses in the gin.[5][6]
Horse gins in the Black Country[edit]
Horse 'gins' were a common site in coal mining areas, and were often used where the coal was shallow, and there was no need to sink deep mine shafts. The gin was a wooden wheel device on a spindle that was pulled round by a horse. This then operated a simple pulley system that raised or lowered loads up and down the shaft.[7] They were most prolific in the Ruiton farm area of the Black Country, which extended to Cotwallend Road. Horse 'gins' were also an extension of the one time illegal mining activities carried out particularly during the Miners' Strike of 1926. Miners dug out the coal from the shallow seam through a series of shallow "Bob Holes", hauling up the coal often in ordinary buckets to be transported away to be sold in the nearby village of Gornal. These activities were believed to have been the beginnings of Ellowes Colliery. The Earl of Dudley halted these activities and legalised them by giving permission for the coal to be mined on a royalty tonnage basis. The shallower coal was mined via the slope or "walking down" method (an extension of the "Bob Hole" method) using horse actuated 'gins'. Eventually, two shafts and steam-driven pit gear were installed to mine the thicker coal further down. The pit closed in July 1951 when the seam was exhausted. The 'gin' used at Ellowes Colliery was believed to be the last working example in the Black Country.[8]
Brewers' House museum[edit]
In Antwerp, Belgium, the Brewers' House museum[9] is a good example of horse-powered pumping machinery. The building dates from the 16th century; although the original wooden machinery was replaced in cast iron in the mid-19th century, the original layout has been retained.
Horse mills still in use[edit]
The Noah Hoover Mennonites, an Old Order Mennonite group, that does not allow any engine power at all, still has several horse mills in use, both in the US and in Belize in Central America. The mills are used to power e. g. a sorghum-cane juicer in Scottsville, Kentucky or saw mills in Springfield and Pine Hill, both in Belize.[10][11]
Old mill, Othonoi, Greece
Citations[edit]
  1. ^ a b c Curtis 2008, p. 376.
  2. ^ a b de Vos 2013, p. 178.
  3. ^ Curtis 2008, pp. 375–376.
  4. ^ a b c See images in Commons category:Gin gang and Commons category:Horse mill, or for further information contact the agricultural department of Beamish Museum Archived 2010-03-28 at the Wayback Machine. There is no printed or online citation for this horse mill or building.
  5. ^ "History Of Mining In Nottinghamshire | Mining Museum Nottingham | Nottingham Industrial Museum". www.nottinghamindustrialmuseum.org.uk. Retrieved 31 July 2017.
  6. ^ "1700 - Horse Gin". www.locallocalhistory.co.uk. Retrieved 31 July 2017.
  7. ^ "Black Country History". Archived from the original on 2017-08-30.
  8. ^ "Black Country History". Archived from the original on 2017-08-30.
  9. ^ Brouwershuis Antwerp, Inventory Historical real estate Flanders
  10. ^ Horse powered saw mill, Belize at YouTube
  11. ^ "visiting Daniel Hoover Mill in Scottsville KY - YouTube". youtube.com. 2016-01-04. Archived from the original on 2016-01-04. Retrieved 2024-02-19.
Bibliography[edit]
  • Curtis, Robert I. (2008). "Food Processing and Preparation". In Oleson, John Peter (ed.). The Oxford Handbook of Engineering and Technology in the Classical World. Oxford: Oxford University Press. ISBN 978-0-19-518731-1.
  • de Vos, Mariette (2013). "The Rural Landscape of Thugga: Farms, Presses, Mills, and Transport". In Bowman, Alan; Wilson, Andrew (eds.). The Roman Agricultural Economy: Organization, Investment, and Production. Oxford: Oxford University Press. ISBN 978-0-19-966572-3.
  • Animal Powered Machines, J. Kenneth Major. Shire Album 128 - Shire Publications 1985. ISBN 0-85263-710-1
  • Water-mills windmills and horse-mills of South Africa, James Walton. C Struik Publishers, 1974. ISBN 0-86977-040-3
  • "The History of Rochester, New York" by William F. Peck, D. Mason & Co. Publishers 1844
See also[edit]
