Econology forum in englishNew 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
inventor
Message non lupar inventor » 04/01/14, 18:19
So embarrassing new year to start something pleasant .. Here, the recording band Blue Black and Ada and Wojtek cover what is served up at concerts in the Soviet Union in 1973, passing from the scene, the better, "my Friend" than the "cold war" .. ..
And I think I succeeded ..
Ada unfortunately died 1 January 1991.
http://www.youtube.com/watch?v=famP4wb5vac
Here, too, if someone did not know that Beatles song and accompaniment of the Kings ...
http://www.youtube.com/watch?v=_wG6Cgmgn5U
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 05/01/14, 02:08
So on your way I think, why this project Manchattan taken a Pole, who only since the outbreak of war in 1939 was in England .. After all, his English was not too good for sure .. British citizenship also quickly got something to this project could attend ... ... But I know war, accelerates various activities ... But the English did not really even war .. Therefore I am full of admiration .. as a sincere desire ..
Here in the video you can see, the then fairly good the English had ..
Each fought as best he could to make this world a better place .. Sometimes it was not easy ..
http://www.nfb.ca/film/strangest_dream
:D
Andrew Feliks
inventor
Message non lupar inventor » 07/01/14, 00:23
Andrew Feliks
inventor
Message non lupar inventor » 13/01/14, 12:07
Well, here , a movie that shows that " spoon effect" is possible to obtain a large area, no such model of the wing , set " bellies " to each other. Between the wings , air is blown using an ordinary hair dryer .. The second part of the film , you will see that blowing this way only one wing , we can feel the hand , there is some lift of the wing . Simply it is so microscopic that it can not feel , despite the fact that once we're blowing on the wing , then do not . I do not feel any difference. The reason is also that the air dryer has a very low speed, and it is relatively very little ..
However, as we hold as two wings . set ' bellies to each other, and kept at one end , the other end , a very intense vibration , bouncing off each other, as a result of blowing the hair . the film do not really see these vibrations because their speed is high , as the camera does not records so quickly. records and revealed that the image of " waving wings. " In a time while also heard the " clack " of themselves striking the wings .. so attractive force them to each other must be large, as seems the powerful sound of beats between them. wing to descend , and then diverge , and again, there are withdrawal force with each wing , and so the circle. But fairly quickly , despite the relatively large area of ??the wings in relation to a small air stream flowing between them ..
In any case , it is this force several times to each side of the Astringent greater than the lift of a single wing , which you can not even feel that there is in these conditions ..
http://youtu.be/KpIWhqW7lWA
Andrew :D :D
Andrew Feliks
inventor
Message non lupar inventor » 27/01/14, 10:57
Of course the pipe that goes through the negative pressure means can be any lengths, and generators placed On the surface of the earth .. This may be from a set of several such sets ..
Andrew
:D
Andrew Feliks
inventor
Message non lupar inventor » 27/01/14, 10:58
Here a further explanation of why dual Red Baron can give at 100km / h about 300 mm of mercury vacuum. .. . ..
Here is a pdf of the classical venturi air, and why is it used double nozzle.
http://www.new4stroke.com/Venturitubes1937.pdf
And now, what are the parameters of the two nozzles that you can buy .. of similar size
The first nozzle gives 4 inches (101 mm Hg) of vacuum of mercury and has a length of 10 inches.
http://www.aircraftspruce.com/catalog/i ... nturi2.php
The second nozzle gives up 9cali (228 mm Hg) of mercury vacuum, and the length is 11 1/4 inch. That is 11% plus growth in vacuum and lengths are more than 100% .. That depends on the vacuum from a very proper way to design the nozzle ..
http://www.aircraftspruce.com/catalog/i ... nturi3.php
Similarly, the need to design a properly configured dual Windmill Red Baron to repair the effects were good.
Here you can not scoff case.
The rest will depend on the size of the system..
Andrew
:D :D
Andrew Feliks
inventor
Message non lupar inventor » 03/02/14, 00:32
Underground sarcophagus must be the first in Fukushima.
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 06/02/14, 01:47
Here, as the tunneling doing in the world, quickly and as cheaply ...
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 12/02/14, 20:37
So, here is the sea, the British shows them for years, as same storms the fenced off shore .. which formed small pool ... Now the water accumulated there, you can refer back to the sea, but by the turbine, which will be make electricity .. The simplest solution ... A little more civilized, I invent .. here they are. Even with the smaller waves works .. In Scotland, the annual average wave height is 3 m .. And the car would probably put a nuclear engineers to examine how quickly the corrosive materials used in its construction .. In the video you can see that even a police officer imagines that in such a way that you can produce energy ..:rolleyes:
https://www.facebook.com/photo.php?v=817204154961489
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 12/02/14, 21:22
Andrew :lol:
Andrew Feliks
Suggestions d'autres pages pour vous: (si rien ne s'affiche, désactivez votre Adblock...)
Revenir vers « Econology forum in english »
