I think that we have come to some stage in the publication of new technical ideas. Although I still have a little to be published, it seems to me that at the moment you need to get to the Philosophy that the publication did not go to waste. So I propose that you read how this Philosophy looks at the present day historical perspective....:rolleyes:
http://en.wikipedia.org/wiki/Creative_destruction
Andrew
New 4 stroke engine (en anglais)
- inventor
- J'ai posté 500 messages!
- x 82
A bit of candles [*][*]
http://inter-sat.com/atle/AVISOPPSLAG77.html
http://www.youtube.com/watch?feature=pl ... bkc9ZgUmVY
Andrew Feliks
I do not quite understand, from where in the Fukushima irradiated with so much water? Surely you can create a flow of water to cool the reactors and pools, which will be held between the radiated heat exchanger reactor cooling water and the tank and clean water cooler .. then irradiated water will return to the cooling of the reactor, and there will need to be storable. Only the top up, if there are any leaks in the reactors and fuel pools .. However, pure water can be cooled by large air coolers and passed through a heat exchanger ..
http://en.wikipedia.org/wiki/Heat_exchanger
Andrew
Andrew
- inventor
- x 82
As befits any career should begin at shoe shine boy .. The then love will be complete ..:rolleyes:
http://www.youtube.com/watch?v=e3st6UcR ... ture=share
And this looks like one of her recent performances
http://www.youtube.com/watch?v=fPQV2GgXQFY
Andrew Feliks
- inventor
- x 82
Well now you can feel what it means to totalitarianism .. Well so you know, I'm also a sound engineer for 40 years .. Realized about 10 000 concerts during this time, and in Poland and other countries .. I worked for this time of większąśćią Polish artists., Listening to the radio and watching TV .. Are you able to imagine that over the 40 years, never, never heard of is the Polish artist Alex and live in Norway .... It was not until she died on September 17 could learn about it. Do you know what you can feel, as for 40 years I have been deprived of access to my National Culture at the highest level, simply because they have a different political views ... She is so secretive about the Polish audience ..
But it's good that I found out about it .. .
now understand more why it happened ..
This is more or less the same as if you over 40 years have never heard of "The Roling Stones".....
the Polish version of Wikipedia:
http://en.wikipedia.org/wiki/Alex_Naumik
"Because of its anti-communism was criticized and marginalized by the leftist Norwegian media. While gold records and international recognition, already in 1977, during the inauguration of a rock concert with the Swedish star of Cornelis Vreeswijkiem was booed by the Socialist Youth. To the outrage of fans everywhere including the omitted the state television NRK television series on the history of rock music in Norway."
So I think that Breivik may have belonged to the outraged....
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Aleksandra is buried in Kluczbork next to his father in the municipal cemetery.
In Norway, on the death of the most important newspapers write "Dagbladet" and "VG".
She was very devoted to his father, after his death, has released an album entitled "Daddy's child"
Farewell ceremony will be held on Friday, October 11. Funeral Mass will begin at. 11.00 am in the church. Our Lady Help of Christians in Kluczbork. Burial in the municipal cemetery will begin at. 12.00.
http://www.youtube.com/watch?feature=pl ... iK6iea65BU
Andrew Feliks
- inventor
- x 82
Well after that our mourning have something on the front ..
No. So designing a good amplifier that amplifies much is not simple and easy ..
Here, it's about the type amplifier wind instruments. On this page, the instruments are charts that say the sound intensity can vary over a range frequencies with as much as 6 dB.,. This large difference is due to raw material from which it is made ??instrument, with the same shape.
http://www.acoustics.org/press/133rd/2amu4.html
If we want to get a change of size (volume) using a classic amplifier-loudspeaker system is to get the 6 dB of sound, we need to use as much as 4 times greater electrical power, not, for example, 50 watt, well, up to 200 watts .. Up so much growth in sound, as it turns out, it gives us the right material for the trumpet ..
https://ccrma.stanford.edu/CCRMA/Course ... 0000000000
http://www.globalrph.com/master_speaker.htm
Yes, we can easily lose with this energy gain, as we will use the wrong material ....
Now the one of the simplest experiments of physics ..
It is a "kitchen an experiment." We take two tablespoons can be of tea or soup. Take them by their ends and bringing together bellies ... Between tummy wpuszczmy very small stream of water. I bet that you will not be able to maintain a 2 mm gap between them ...
We can also repeat the experiment horizontally, so that the speed of the fluid force is created ..
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Well, finally, after a year, I received a cut down water, the elements of Plexiglas to model "Halfrotate Engine 1000 cc volume" ....
He is set to keep on hand, has 100ccm cylinder capacity .. 4 x 25.4 cm ^ 2 surface and 1 cm thick ..
to 1000 ccm this height h = 10 cm ..
to 3000 ccm this height h = 30 cm .......
First impressions: the piston surprisingly easy to change direction when moving your fingers inside the "barrel" .. I think very highly rotary engines will also be
possible to build ..
Andrew
Andrew
Andrew Feliks
Revenir vers « Econology forum in english »
