Econology forum in englishNew 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
inventor
Message non lupar inventor » 27/07/12, 12:27
Whether engineers will pretend that the atomists still do not know the new inverter UPS Technology on batteries, which in the case of a power failure, it is ready within fractional seconds to the provisioning of the full effect of emergency systems ???
Of course, some diesel then can long function.
But I think, with this reason for savings, because and so nuke is already insanely expensive.
http://www05.abb.com/global/scot/scot235.nsf/veritydisplay/1fbaf829798d9615c1257870003576c1/$file/des_brochure_rev_c.pdf
Andrew
May repulsion to techniques derived from green energy does not permit widely its integrity in nuke ...
:frown:
Andrew Feliks
inventor
Message non lupar inventor » 09/08/12, 01:11
Monument to the victims of the earthquake in its epicentre in Tashkent. You can see clearly the huge cavity, in which the trees are growing, and despite their vertices do not protrude above the ground of the monument, the cavity is approx. 50 m depth.
And talk to someone it does not appear that build the atomic power stations on earthquake-resistant, ...Jan Christian Andersen Fairy Tales. ...
I have seen. I recommend a trip atomist engineers in particular.
Andrew :cry:
Andrew Feliks
inventor
Message non lupar inventor » 16/08/12, 09:29
This is now seriously with these atomists...
And I am evaluating, so most of my friends of cancer in various forms leaves prematurely.And here you have a surprise
Something that, after these liar nuke not I expected!
http://ex-skf.blogspot.com/2012/04/blue ... -bqkg.html
Andrew: :cry: :cry:
Andrew Feliks
x 38
Message non lupar Remundo » 16/08/12, 10:34
Hi Andrew...
Nuclear power is a great danger. And mankind can do without nuclear electricity.
Recently, everyone has seen it in Fukushima. Japan has still electricity and is launching big projects for renewables, although it is still dependant on fossile fuels.
Some japanese independant biologists have shown worrying mutations around the central about butterflies due to radiation.
And is it soon for people ?
"liar nuke" is often a pleonasm... :?
inventor
Message non lupar inventor » 18/08/12, 04:23
Remundo a écrit :Hi Andrew...
In order to provide the reactors in Fukushime from the bottom you have the mechanical tunnel.
Then insert the two meters in diameter with 20 tubes. , Do the holes from the top and side, and on the bottom line fire resistant ZrO2. For large pipes enter the small tube to remove radioactive leaks or cooling corium had reached there...
http://www.herrenknecht.com/fileadmin/r ... -12-21.pdf
http://www.herrenknecht.com/fileadmin/r ... -10-29.pdf
Certainly not the cheapest, but it will give guarantees that the radioactive materials do not enter the land and ocean
Regards Andrew
Andrew Feliks
inventor
Message non lupar inventor » 05/09/12, 02:34
Regards Andrew
Can to remove scrap metal from the reactor 3 can use these electromagnetic grippers?
Also for attaching various devices and cameras probably would be useful..
Andrew
Andrew Feliks
inventor
Message non lupar inventor » 24/09/12, 02:14
Whether, if the sprayer to the treadmill, for example, a car, it will be more supportive of animals?
http://en.wikipedia.org/wiki/Horse_mill
Andrew :mrgreen:
Andrew Feliks
inventor
Message non lupar inventor » 27/09/12, 03:28
I wonder if to ask if these two smiling at us men to graciously evacuated their asses out of this car, it would be possible instead of carriage them to produce some electricity for us? Since drivers are not needed, because the car is harnessed to the treadmill and drivin in circles .. But one thing is certain, that such a vehicle driving the external energy, we will have the wind, regardless of the weather ... AJ is here the energy produced is sufficient to maintain the treadmill speed, it will be good .... And maybe even a few kilowatts for us is for our use ....
And it is always, regardless of the weather ... I do not need to go to the desert to breaking records. This can be done on the treadmill near the house...
http://www.youtube.com/watch?v=bkcn8ZkvKKc&feature=plcp
http://news.discovery.com/autos/how-do-wind-powered-cars-work-111207.html
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 27/09/12, 15:36
http://www.rcgroups.com/forums/attachme ... tid=777461
Of course, the fuel will be coal dust....
Andrew: Wavey
Originally posted by Anth
Of course
I hope you will also agree with this, teeth were the least moving parts. The 5 MW windmill should be placed. Mounted on the ends of the arms jet frame. (ends reach such a large fan wheel 1 Ma), so the jet frame will fit well ... It will be a "small" treadmill
http://en.wikipedia.org/wiki/Ramjet
Andrew :D
Andrew Feliks
inventor
Message non lupar inventor » 07/10/12, 03:18
Ramjet symulation (upper green) Need Java
http://www.grc.nasa.gov/WWW/k-12/Virtua ... gnsim.html
As I see massive construction that are to demolish the building of Reactor No. 3 is me shivers go ..
Certainly the building suffered the most, because it was the biggest explosion. So the walls are certainly very weak, and it seems to me that the water in the pool of fuel remains a miracle there is to do there can not be inspected, that does not mean that the building is sturdy ..
Therefore, demolition should in my opinion not cause additional shocks, and be carried out as gently as possible ... Heavy construction equipment, rather they should not be used ...
They are after all modern methods, such as cutting concrete with water. The company offers cutting up to 3 meters ..
[ur]http://ajaks.eu/en/services-for-civil-engineering/hydrodynamic-demolition-of-concrete--hydrodynamic-robots.html"]http://ajaks.eu/en/services-for-civil-engineering/hydrodynamic-demolition-of-concrete--hydrodynamic-robots.html[/url]
I do not want to think what would have happened, if as a result of the vibrations, the resulting leaks in the fuel pool and the water came out of it ... Almost as a result of radiation inside the building and its three filling remains, you can not to re-seal it. ..
Therefore, even mild disturbances such methods may be used: diamond cut rope ..
http://www.hilti.com/data/editorials/-1 ... et%20e.pdf
https://www.hilti.co.uk/fstore/holuk/te ... 0%20en.pdf
http://www.youtube.com/watch?v=lZ04OdpmJ84
http://www.youtube.com/watch?NR=1&featu ... 54madabs9s
http://www.youtube.com/watch?NR=1&featu ... VI8Z5grdOw
http://www.youtube.com/watch?feature=en ... 8xoHvhiA2k
Andrew :D
Andrew Feliks
Suggestions d'autres pages pour vous: (si rien ne s'affiche, désactivez votre Adblock...)
Revenir vers « Econology forum in english »
